Old 08-07-2012, 11:32 AM
airmel's Avatar
airmel airmel is offline
Default Which ¼ turn fasteners to use on the cowl?
I've read a lot of the threads about the Skybolt and the Milspec quarter turn fasteners for the cowling, but I'm still not sure which to use. It seems that Skybolt has prefabricated tabs now which would cut down on the amount of work , but I want the best looking (flush mount, no corrosion down the road, last forever, etc.). I am planning on using these just along the top cowl at the firewall with hinges everywhere else (except the very bottom!). I'd like to hear from those who have used these (Skybolt and/or Milspec) and some honest opinions! Which are the flushest? Which look the best? Which are the easiest to install/adjust? Thanks!
Melinda Harrill
Flying my RV-7!
Barrett Precision Engine - Superior IO-360 with AFP FI
Garmin Panel - All touchscreens
Old 08-07-2012, 01:46 PM
agirard7a's Avatar
agirard7a agirard7a is offline
Default Skybolts
Skybolts work great. Easy to install and adjust. Drill the
15/32" hole not 1/2". Use a unibit to drill most of the hole
and finish off with a 15/32" bit. Unless you can find a 15/32" unibit.
Supplied mounting brackets work well. You may not
Need a shim between the braket and fire wall flange depending on the
thickness of the fiberglass cowling.
Al Girard, Newport, RI
N339AG
RV-9
Old 08-07-2012, 03:21 PM
gstone gstone is offline
Default Milspec...
Great product and Excellent customer service!!
Old 08-07-2012, 04:51 PM
Rupester Rupester is offline
I feel the same way about the Milspec fasteners and their kits, which come with all the fasteners you need and the tools to install/adjust them. Great product, great service. I go with them again in a heartbeat.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 08-08-2012, 12:39 AM
kbehrent's Avatar
kbehrent kbehrent is offline
Highly recommend Milspec! Good quality product. Easy to install and adjust.
Kevin Behrent
TeenFlight Puyallup, President
www.teenflight.org
http://facebook.com/teenflightpuyallup
EAA Chapter #326
Puget Sound, WA
RV-9A
Aerosport (Superior XP) IO-320 C/S, Precision Eagle EMS
Old 08-08-2012, 06:52 AM
dmaib's Avatar
dmaib dmaib is online now
I am a very happy Milspec customer. Easy to install and adjust for a nice flush fit. But, I have no experience with Skybolt, so cannot give a meaningful comparison. I imagine most of the responses will be similar. Hopefully someone with experience with both products will speak up.
David Maib
RV-10 N380DM
New Smyrna Beach, FL
VAF Paid 1/21/2020
"In '69 I was 21, and I called the road my own"
Jackson Browne
Old 08-08-2012, 07:02 AM
Jaypratt's Avatar
Jaypratt Jaypratt is offline
Default 1/4
NONE!! use the hinges ,,, Looks better
Jay Pratt VAF #2
RV Central - Builder Assistance
Paul Revere, Borrowed Horse, & Shooter
Old 08-08-2012, 09:35 AM
RV8MW RV8MW is offline
I have the skybolts but have not installed them yet and I'm with Jay I think the hinge method looks better so I am thinking about not even using them.
MIKE WARREN
RV8 N184MW RESERVED
TMX-IO360 REDGOLD,HARTZELL CS
CLINTON N.C.
www.mykitlog.com/mwarren
Old 08-08-2012, 09:57 AM
rwhittier rwhittier is offline
Default Skybolts worked well for me
Can't comment on Mil Spec other than I think the fasteners themselves are equal. Check what other parts of the system are available though. With SB's they have the interlocking tabs and an alignment jig (guide) to drill the holes that are extremely useful (even very small hole errors can cause the heads to do weird things). Both add up to make the job much easier. I don't know if MS has those. If they do I guess you can use price to guide you. Good luck.
Roger Whittier
RV7A Quick Build, Tip Up
N1MY Reserved - Canopy finished - Wings mated, Engine hung, electrical 95%
Old 08-08-2012, 10:09 AM
rv9aviator rv9aviator is offline
I have milspec but never installed them. Kind of wishing I had now. The horizontal long hinge pins are still a royal pain to install even after a year of flying. They are so tight I have to use vice grips clamped every two inches at a time to push them in.
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
