Old 08-06-2012, 06:12 PM
md9680 md9680 is offline
Default RV-9A Root Rib and Elevator Horn Issue
I cleco'd the left elevator horn to root rib and spar and, just to see how it would line up with the skin, cleco'd the spar to the outside of the skin. There's quite a bit of divergence from the expected alignment of the rib and skin. The rib is (as per instructions) riveted to the spar but I suspect I might have increased the radius of the riveted rib flange during the "slight bending" to allow the riveting. Since the rib is now riveted to the spar, how can I put the squeeze on that acute angle on the rib flange? Or is there something else I'm totally missing? Thank you for your replies.
Mike Davisson
Edgewood, NM
Cherokee 235
RV-14A #140805
VS complete
Rudder complete
HS complete
Elevators in progress
2021 =VAF= Donor
Old 08-06-2012, 06:28 PM
scard's Avatar
scard scard is online now
Hmm... Worthy of a pause. You didn't change that weldament. I personally don't think you're missing anything. Call Vans. That weldament is funky (you can tell them I said so . Although, 'maybe' the weld gusset will allow you to bend it into proper shape, which might be acceptable.
Scott Card
CMW E-Lift
VAF Advertiser
Old 08-06-2012, 07:33 PM
Well, Scott, it IS a pretty old kit I'm working with and I've replaced several parts already. Maybe they had an early batch of elevator horns out of spec. Thanks.
Mike Davisson
Edgewood, NM
Cherokee 235
RV-14A #140805
VS complete
Rudder complete
HS complete
2021 =VAF= Donor
Old 08-06-2012, 08:59 PM
Default bent?
I know it is easy to bend the horn a bit while riveting, but not that much. You said it was an old kit - maybe it got bent in storage? If you can compare the angle with the other side, that could give you an idea. I think you could bend it to be correct, but it is a pretty critical location and I would check with Vans. It probably isn't very expensive and shipping should be cheap too.
Let us know what they say. Good luck with your build.
rockwoodrv9a
Williamston MI
O-320 D2A
Flying N376E
Old 08-07-2012, 11:23 PM
From Ken S. at Van's:
"Something odd is going on here, but since those parts were shipped well over a decade ago, it's hard to remember if there (were) problems with those parts. Could you get a protractor and measure the included angle of the weldment? I can use that to compare to parts here."
So, I measured 64-65 degrees, for those of you who might be inclined to check your elevator horns.
Will post more info as I get it...
Mike Davisson
Edgewood, NM
Cherokee 235
RV-14A #140805
VS complete
Rudder complete
HS complete
2021 =VAF= Donor
Old 08-08-2012, 11:55 PM
flyinmonque flyinmonque is offline
Default It's been a long time but.....
........Seem's to me you have the right horn on the left side.
