Old 08-03-2012, 08:07 PM
bsacks05's Avatar
bsacks05 bsacks05 is offline
Smile When to replace a tail wheel?
After 670+ hours my 6.0 diameter tail wheel is now 5.3 inches dia. Is there a reason to replace it now? Perhaps at 1000 hrs? By then it should be about 5 inches. I'm using vans budget ($35) wheel.
Bruce Sacks
RV-9 N659DB - Flying since 7/1/06
Hatz CB-1 - Fabric covering with Polyfiber.
Warner Robins, GA
A&P
APRS KJ4EFS
Old 08-03-2012, 08:16 PM
Bruce, I replaced mine at 6XX hours. I figured the smaller diameter of the worn wheel put my tailwheel steering post even closer to the ground and made it more susceptible to getting snagged on a taxiway lip. I'd prefer to spend $35 a couple of years early than to have some random object tear out the tailwheel mounting bracket...
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 08-03-2012, 08:34 PM
n5lp's Avatar
n5lp n5lp is offline
fugio ergo sum
It probably doesn't really matter but what I think about is the RPM more than the clearance. When the wheel is worn down to where it is really whizzing along, in my mind; that is when I replace it.
Also, when it gets too squared off it just doesn't look right.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
Old 08-03-2012, 08:41 PM
Steering is harder too, with the bigger contact area.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 08-03-2012, 09:15 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Oftentimes, the bearings go while there is still plenty of good rubber.....
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 08-03-2012, 10:00 PM
vfrazier's Avatar
vfrazier vfrazier is offline
We've got better tires with better bearings, retrofit forks with better clearance and handling, and lots of other RV goodies.
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
Old 08-04-2012, 11:08 AM
bsacks05's Avatar
Thanks for everyone's input. I think I understand, replace the tail wheel before it becomes a tail skid. When I was building I would keep the tail wheel on my office desk as a little tangible incentive of what was to come when I finished the plane. Now I guess it will get returned to my desk as a reminder of the incredible first 700 hrs of RVing
Bruce Sacks
Warner Robins, GA
A&P
APRS KJ4EFS
Old 08-04-2012, 04:24 PM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
+1
Happy customer of the sealed bearing deluxe tailwheel here! Highly recommended.
Next I need to get the angled tailwheel fork, but after Oshkosh, and coming home to have to buy a bunch of expensive parts for my Audi Quattro, it'll be a couple months for my wallet to recover.
Neal Howard
Airplaneless once again...
Old 08-05-2012, 04:34 PM
Mark Browning Mark Browning is offline
Cool
Originally Posted by Neal@F14 View Post
+1
My 2 cents of advice, is to keep your standard vans tailwheel as a spare...
Buy the delux wheel from Vans and spend an additional $20 on a pair of quality sealed bearings; (the chiniese bearings that come with it dont last) The wheel looks cool and you dont get all that anoying greasy dirt with the delux wheel.
The only trouble with this wheel is the time i spend polishing it
Old 08-06-2012, 11:55 AM
vfrazier's Avatar
Mark,
Unless, I'm missing something here, you appear to be showing Dayton Murdock's lightweight wheel in your photo. It comes with good, sealed bearings already installed.
The "deluxe" tire is sold by us. It has a nylon type hub and sealed bearings. Van's doesn't carry this tire.
Either of these tires should be a huge improvement over Van's tire with it's grease slinging bearings and rather poor tread life.
Vince Frazier
www.f1aircraft.com
