Old 07-31-2012, 07:03 AM
tomhanaway tomhanaway is offline
Default Attaching pulldown strap for doors?
I have a pair of straps (Abby's Flightline) for pulling the doors down while in the plane.
Any suggestions for best place/way to install (and/or pictures) would be great.
Tom hanaway
Tom Hanaway
Moved to Murphy, NC
RV-10/N518TP-sold
repeat offending-8A N116TP-Now Flying
based in Copperhill, TN 1A3
Old 07-31-2012, 07:54 AM
rleffler's Avatar
rleffler rleffler is offline
Tom hanaway
Good questions.......
I had purchased some straps myself, but forgot about them until my doors were sealed back up and finished. I could use a rivnut, but I'm not sure that the thickness of the interior shell would be durable enough to support the strap unless reinforced with an aluminum doubler behind it.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 07-31-2012, 07:55 AM
pierre smith's Avatar
Default Yep.
Tom, mine are tied around the door handle shaft. Tuck them down next to you in flight. Three years, no problems. BTW, Jenny added about an ounce of lead fishing weight to ours, so that the wind doesn't blow them out of reach.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 07-31-2012, 05:27 PM
Strasnuts Strasnuts is offline
FWIW,
I thought I would need something to pull the doors down but just reaching fwd of the fwd hinge is an easy reach and I can manage the co-pilot's door from the left seat.
Some pilots like the handle, just thought I would mention they aren't required unless you are really height challenged. I'm 5'10".
A&P RV-10 Flying 1000+ hours
SuperSTOL Flying 170 hours
Old 08-01-2012, 04:55 AM
You can't reach the doors when you're standing on the ground...hence my pull-straps....I'm 6'
Best,
Pierre Smith
RV-10, 510 TT
Louisville, Ga
Dues gladly paid!
Old 08-01-2012, 08:55 AM
paul330 paul330 is offline
Do those with a strap have some sort of catch inside that it can be looped round so that you can taxi with the door ajar?
Paul
Mercy Air, White River FAWV
RV-10 ZU-IIZ - "Zeus"
2019 Donation Made
Old 08-01-2012, 09:45 AM
Paul, I wrap mine under and around my thigh for taxiing with the door slightly open.
Best,
Pierre Smith
RV-10, 510 TT
Louisville, Ga
Dues gladly paid!
Old 08-02-2012, 02:30 PM
johngoodman's Avatar
johngoodman johngoodman is offline
Originally Posted by Strasnuts View Post
FWIW,
There is absolutely no way I can reach the co-pilot door from the left seat, unless I unstrap and use the co-pilot as a support. I'm 5'9". Moving on, I use a strap on the door handle - especially important as Pierre pointed out, when you are standing on the ground. Using the strap to retain the door partially open while taxiing sounds good until you try it. There is just too much unpredictable gusting going on out there. I'm working on something, I'll let you know if it works.
John
John Goodman - 40572
First flight was 25 June, 2011
N711JG
Old 08-02-2012, 05:09 PM
I forgot to mention my 7 foot reach.
Old 08-03-2012, 08:43 AM
Moura Moura is offline
Any pics of the strap installed?
