Originally Posted by Ironflight
I asked Gus about that, and he indicated that it was the grip that Van's sells....I nver checked their online store when I got back.
Paul's right. It is the plastic grip available in the cat., but it has been modified.
That particular grip is intended for single hand use, so it needs to be modified when used on both sticks of a side by side airplane. It also was modified for PTT and flap activation. The plastic it is made from is easily reshaped by filing/sanding.
