Old 07-21-2012, 02:09 AM
Rainier Lamers Rainier Lamers is offline
Default MGL EFIS - new fuel flow sender
We have released a new fuel flow sender for MGL EFIS systems as well as our smaller flow indicators.
This unique flow sender uses a new method to measure fuel flow which eliminates bearings and friction. It is very small and has a very low weight and can be used in any orientation. It is not affected by G forces.
It is also lower cost than alternatives...
Rainier
CEO MGL Avionics
Old 07-21-2012, 02:31 AM
digidocs's Avatar
digidocs digidocs is offline
We're all dying to know... How does it work?
Old 07-21-2012, 03:27 AM
The manual is at www.MGLAvionics.co.za - you will find a link on the "welcome" page.
Effectively there is a small but very precisely micro-machined "thingy" inside the aluminium body of the sender. Fuel passes this object in such a fashion that the fuel rotates around the body in an axial fashion creating a vortex, suspending the object in the fuel and the object rotates with the vortex. The rotations are measured contactless by the black sensor body in the picture - this contains all the electronics, even a micro processor. The black part simply clips off so you can install the aluminium body in the fuel line easily - when done simply clip the sensor electronics onto the body. A red LED flashes when flow is detected (just as additional aid to the installer).
It's pretty simple. Most good ideas are simple.
Rainier
CEO MGL Avionics
Old 07-21-2012, 09:13 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Needs AN fittings, not hose barbs.
Or, is this for the Rotax and similar engines?
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 07-21-2012, 02:41 PM
aerhed aerhed is offline
Pretty cool tech, but Mike is right. Needs AN Fittings or nobody on here will use it. We like to stay at least one shelf above the flying lawnmower dudes.
Actual repeat offender.
Old 07-21-2012, 03:02 PM
DCat22's Avatar
DCat22 DCat22 is offline
Looks like... Site says:
Single range fuel flow sender optimized for flow rates up to approximately 50 liters/hour.
Compatible with 4-6mm ID hoses and similar imperial sized hoses.
Compatible with a wide range of fuels including those with methanol and alcohol content.
Mechanical failure of the sender will not block the fuel flow.
The fuel flow sender is compatible with all of MGL Avionics range of products.
Ideal flow sender for Rotax 912/914 series engines and similar makes of this size.
Take a look at the taken apart pics on http://www.mglavionics.co.za/Docs/MG...w%20sensor.pdf though... I like the design when it will work for the rest of us. (I'm guessing the ~12 gp/h top end would be limiting as well?)
-Rick Greer, VAF #2492
Old 07-22-2012, 12:27 AM
We will be doing a high flow range version as well. AN fittings are also on the cards.
Rainier
Old 07-22-2012, 09:17 AM
You better have it ready by the time I need an IEFIS for the next ten or else I'll.......never mind I'm pretty sure you'll beat me.
Old 07-23-2012, 12:43 AM
This particular flow sender has been used in the last Dakar rally at flow rates of up to 70 liters/hour without issues. The origins of this flow sender lie in motor sport.
The version we are releasing for aviation purposes is slightly modified in that it has less flow resistance at the cost of less accuracy at very low flow rates that are not used in aviation anyway.
Rainier
CEO MGL Avionics
