Go Back   VAF Forums > Education > Flight Testing
Old 07-17-2012, 08:03 AM
Default Testing at max gross weight
The Phase I endorsement for the logbook that's required seems to suggest that the testing for V speeds should be done at as many different weights as possible, which would seem to include maximum gross weight.
I'm 170. Full fuel is 250... give or take... which gives me about 350 pounds for ballast I'd need in a fashion that allows me to move it forward and back.
What are people using to provide this much ballast (in an affordable way)?
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 07-17-2012, 08:07 AM
boom3's Avatar
boom3 boom3 is offline
Hi Bob,
I used 60lb bags of concrete. Just put them each in a garbage bag so you don't get dust all over. I took out the passenger cushions and they stack up nicely and can be belted in.
Jeff Bloomquist
Sumner, WA
PP-ASEL, IR
RV-7A
Flying
1150 Hours
Old 07-17-2012, 08:08 AM
Kyle Boatright Kyle Boatright is online now
I strapped duffle bags full of dumbbell weights and sandbags into the pax seat and baggage area.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 07-17-2012, 08:24 AM
Gash's Avatar
Gash Gash is offline
I put my 350 pound mother-in-law in the back seat. (alright, just kiddding)
Karl, Goodyear, Arizona (KGYR) ATP, CFII
RV-14A, Flying
Extra 330LX, Flying
RV-8, Sold
RV-7, Sold
Bearhawk 4-Place, Sold
=VAF= donor 2020
Old 07-17-2012, 08:44 AM
airguy's Avatar
airguy airguy is offline
Can't do that - I got rid of that wife...
Old 07-17-2012, 09:13 AM
jjconstant's Avatar
jjconstant jjconstant is offline
I used sand bags in various tote bags and used the handles of the totes to tie the bags to spots to keep the weight from shifting. In the baggage area I tied it to the central flap housing and varied the length of rope for various loading scenarios. I also put various weights in the passenger seat and ran the seat belts through the tote handles. It was still a bit messy until a friend loaned me some bags of lead shot which I also put in the totes for securing. Much easier with the bags of shot.
All Best
Jeremy Constant
RV7A "Stella Luna" ECI IO-360 WW200RV Pmags 360hrs
VAF 2019 paid plus some for those who can't
Old 07-17-2012, 10:31 AM
BillC BillC is offline
Talking
Large dog food bags #34. We use to breed Boxers so the extra bags didn't go to waste. Not as dense as concrete but not as messy if/when the bag breaks open.
YMMV
Bill RV-9A Flying
FFI- Flight Lead
N99WC
Ramona, CA (KRNM)
Old 07-17-2012, 10:56 AM
krw5927 krw5927 is offline
YMMV
Just don't be surprised when all the airport dogs chase you down the taxiway.
Kurt W.
RV9A
FLYING!!!
Old 07-17-2012, 04:43 PM
thinkn9a thinkn9a is offline
Default Do be careful,... especially when working on fwd cg
make sure what ever you use will not shift with bumps, acceleration, or deceleration.... plastic bags are bad about sliding around...
you don't want something heavy sliding onto the stick or into the rudder pedals,... similar... certainly don't want all your ballast going aft when you takeoff.
I used bags of oil-dry, (can re-use later during oil changes, etc) ... and weights from a weight bench.
Wallace & Marietta Goodloe
9A -QB
N211LV
Phase 2 has started!
Thanksgiving time, is dues time for us
Old 07-17-2012, 04:56 PM
Boy, none of these do much for me. If I'm doing a 60 knot climb, everything's gonna shift. the box of lift weights (all duct-taped up and strapped in) might work. There's just so little room on a seat without messing with the passenger stick (I know what you're about to write, but it's bolted in per the plans and it ain't coming out!)
Bob Collins
St. Paul, MN.
