Old 07-16-2012, 09:04 AM
N282S's Avatar
N282S N282S is offline
Default searching
Your knee cap will find the rivet you dropped yesterday while crawling around looking for the nut you dropped today.
Steve Stucky
Topeka, Ks
N282S - VariEze 500+ hrs
N283S - RV-7 1400+ hrs
KC-135 A/D/E Boomer (Ret.)
Old 07-16-2012, 09:05 AM
N282S's Avatar
Default long reach
Any object rolling off the work bench will immediately roll to the far wall under the work bench.
Exception: Xacto knives will land on the blade prior to rolling to the far wall.
Steve Stucky
Topeka, Ks
Old 07-16-2012, 09:07 AM
N282S's Avatar
Default lost and found
A lost cell phone can be found just after mixing epoxy or pro-seal
Steve Stucky
Topeka, Ks
Old 05-23-2013, 10:20 PM
Blain's Avatar
Blain Blain is offline
Kinda hate to spoil the fun with a serious tip. But I needed to share it with someone anyway;
Use the right tool for the job.
I had an air hammer. Looks just like any 2x or 3x in various vendors sites. Attempted the tool box kit with my gun and the correct rivet sets. After watching the sets bounce across my shiny aluminum I decided something is wrong here. Bought the gun that A/S sells with the RV tool kit. I'm sure most everyone reading knows what I discovered.
Setting rivetes with that gun made me buy the -8 Emp kit.
Blain
Old 05-23-2013, 10:31 PM
I won't even show anyone my toolbox kit. It is total ****. The hinge doesn't work, hammer marks all over it. I am just glad I got the toolbox first!
Hey - I grew up in Cameron Park and taught at Rolling Hills for 7 years. We moved to Colorado about 6 years ago. Mike S is up on the airpark and would be a good person to contact for help. Just a few minutes with someone that knows what is going on makes a huge difference.
Have fun with your build.
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
Old 05-24-2013, 01:03 PM
Blain's Avatar
Sounds like everyone has had the same learning curve. I have made contact with Mike.
Blain
Old 06-12-2013, 06:42 PM
BonitaRV8 BonitaRV8 is offline
When moving fast while installing rivets and using your thighs to hold the rivet gun while you insert the next rivet into the hole be, sure you dont squeez the trigger!
Empannagee done
Wings 90% done
Received fuselage
Old 07-05-2013, 02:39 PM
DaleB's Avatar
DaleB DaleB is offline
When you plan the budget for your airplane, remember double it. In order to move on to the next major expenditure, you're going to have to do a remodel project or some similarly expensive thing to preserve domestic tranquility. I can't afford an engine for a while now, but we have a REALLY NICE new master bath.
REALLY nice.
You know, like "I could have bought a new Lycoming and a G3X panel for this much" nice.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 07-05-2013, 08:54 PM
N804RV's Avatar
N804RV N804RV is offline
Originally Posted by klovning View Post
1.)
If you run into a build problem (e.g. a hole in the control horn on the right elevator and the bearing bushing don't quite line up perfect) take a day or 2 to think about it.
The answer will often come to you while doing something else. (in this case an appendectomy) ...
Now I know why the chief of surgery carries around a rivet fan!
Ken W.
Mount Vernon, WA
2020 VAF Supporter
Old 07-11-2013, 11:23 AM
brianwallis's Avatar
brianwallis brianwallis is offline
VAF moderator
Default fuel lube or assembly fluid
Tight spots with hardware can be dealt with nicely by putting some fuel lube or assembly fluid on your finger. This sticky stuff keeps washers/nuts etc on your fingertips until they are on properly
Brian Wallis
(Exempt AND VAF dues paid 02 FEB 16)
Callsign: VOODOO sold RV3 to pay for ratings !!!
AP/IA COM/Multi/IFR/350 type
