View Poll Results: Fair Price for 6-lobe Alloy 8-32 Cad II Plated Pan Hd Screws
100 peices @.50 each 0 0%
100 peices @.32 each 7 10.94%
100 peices @.25 each 31 48.44%
100 peices @.20 each 16 25.00%
100 peices @.16 each 10 15.63%
Voters: 64. You may not vote on this poll
  #11
Old 07-07-2012, 08:31 AM
RV8TOR RV8TOR is offline
Are these same spec screws available in hex drive. I have a lot of areas where I cannot get over center on the screw to install/remove and a ball hex drive seems to work.
Charlie Kearns
2009 RV8 N213CK
1976 C180 N9979N
Javron PA-18 in progress
Old 07-07-2012, 09:36 AM
gtmule gtmule is offline
I went to all high-strength structural (NAS 517, AN525(?) or similar) and started using nice phillips bits (Bosch, from Lowes) and am no longer having as much trouble. That said, I'd be in for some for the more problematic spots (inside the cowel openings, the under side of wheel pants, etc) where it's still easy to bugger the phillips up.
Macon, GA (KMCN)
RV-7, Niner Fife Victor
Old 07-07-2012, 10:37 AM
videobobk's Avatar
videobobk videobobk is offline
I would take Torx (or whatever you call them, I guess Torx is a tradename) over Phillips any day. It takes a few more tools, but they almost never strip out. Less effort than pushing hard to keep a Phillips seated. I will say that Torx bits don't seem to last as long as a good Phillips screwdriver.
Bob Kelly, Scipio, Indiana
Tech Counselor
Founder, Eagle's Nest Projects
President, AviationNation, Inc
RV-9A N908BL, Flying
Old 07-11-2012, 12:10 PM
GAHco's Avatar
GAHco GAHco is offline
Thumbs up Gaining on it!
To be able to break even with the first run I need to sell 200+ packages of 100 peices.
Posting any comment along with participating on the poll would be benificial that also keeps us more visible in the forum.
Thanks for your votes and comments.
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
Old 07-11-2012, 12:20 PM
scsmith scsmith is offline
Default Also #6, and 100-degree F.H.
I would buy both flat head and button head, in both #6 and #8.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 07-11-2012, 12:28 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Originally Posted by RV6_flyer View Post
I had to look up what 6 lobe screws are. I have not heard them called that before. To me it looks like they just another name for Torx fasteners.
Tom, can you confirm that the screws you are talking about are what most of us refer to as "Torx".
I would be interested in changing out all the Phillips head screws in my plane, that require frequent removal, both flat and round head, #6 and #8.
Also, if these are not actually "Torx", will you be offering a driver to fit the screw heads??
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 07-11-2012, 12:38 PM
F1R F1R is offline
I would much prefer TORX drive heads over philips and would take a hundred each of the 100 deg. CS head and dome head in #8.
Old 07-11-2012, 02:06 PM
edsong's Avatar
edsong edsong is offline
Default Torx
I'd take 2 packages of each style and size. Probably more.
Edson Grindeland
Hatton, ND
RV-8 Flying
http://www.hattonflyingcircus.com
You do not need a parachute to skydive. You only need a parachute to skydive twice.
Old 07-11-2012, 02:07 PM
FresnoR's Avatar
FresnoR FresnoR is offline
correct me if I'm wrong, but I believe "torx" is a brand name and copyrighted, so the generic term for them is commonly "6 lobe screws"
Rick from Fresno
RV-7A
The art to flying lies in learning how to throw yourself at the ground and miss.
Old 07-11-2012, 04:09 PM
mlwynn mlwynn is offline
Default 6 Lobes
I have used torx head for prelim assembly on lots of stuff. I have gone to "aircraft grade" phillips for the final assembly. I would MUCH rather use the 6 lobe. I would probably take a couple hundred in #6,#8 100 degree flat and button or simiar head.
Thanks!
Michael Wynn
RV 8 Finishing
