Of course you can cut your own panel! This is the way we did it before the Panel Pro was available and there are some really nice looking home made panels out there. If time is not an issue, and you are willing to accept imperfections, have at it.
Remember though you (and your passengers) look at the panel every time you fly. Someone that is inexperienced with panel layout will draw each cutout individually (assuming they have access to CAD). I can't tell you the number of times I have seen panels drawn by people that know CAD, but not neccesarily Instrument panels that have mounting holes wrong or unsymetrical, or the cutouts way oversized leaving ugly gaps.
Shops that have the Panel Pro panel cutter have a drawing library with the cutouts that are proven correct, they also make sure your edge to edge distance is acceptable because the drawings include the bezel (case) of the instruments. Before you ask, the Drawing Library is only available if you buy a Panel Pro.
Bill Morelli's panels come out nice because he not only works with your sketch and make recomendations based on experience and a desire to help, he has the tools to do the job using the Panel Pro.
I used the Panel Pro to help fabricate my RV7A in a year and a half. I made a bunch of parts in addition to the panel with the Panel Pro. Take the canopy latch for instance. The punched part from Vans had a gazillion little punch marks that had to be filed smooth. In addition the part was warped from the punching process. I digitized and cut my own using the Panel Pro. The result is a perfectly flat part with very minimal burr.
Let me say this again. Everyones goal is a bit different. If yours includes hand forming every part possible using your own hands and a rock have at it.
If you want to spend your time putting the pieces together and making an airplane you can be proud of, buy your own Panel Pro or give Bill Morelli a call.
http://www.bullerent.com
