07-02-2012, 01:16 PM
Is it possible the return line in the fuel tank fell down into the tank. Mounted correctly in the filler neck the return line has no back pressure. If it were to come loose from the top of the tank and fall into the tank and get submerged you might get some back pressure that could give you varying flows when the tanks fuel level changed from full tank to half or quarter tank.
07-02-2012, 01:50 PM
My experience today - -
It was a toastie 33 C at the airport ( about 980' ). I climber to 7500', and it was a nice 18 C ( about 66 degrees F ). I noticed my fuel flow also rose higher than normal. For the RPM I was at, I would normally see about 4.8 GPH. It was reading 5.8 GPH. The DA was at 9750' when I was at 7500' ALT. I stayed at 7500' for about 1/2 hour. Everything else was pretty normal, but fuel flow was higher. Seemed ok once back on the ground.
John Bender
397.8 hours
07-02-2012, 01:54 PM
I know our carbs are supposed to be altitude compensating[/quote]
Rotax carbs are not altitude compensating. They are sometimes called "constant velocity carburetors"
don
07-02-2012, 11:08 PM
Semantics?
"The fuel/air mixture the carburetor provides to the engine varies with air density. Air density fluctuates with ambient temperature and altitude above sea level." Quote from Rotax literature
This may not meet the definition of "altitude compensating" exactly but it must be pretty close
Tony
Tony
E-LSA RV-12 ULS
07-03-2012, 05:57 AM
Not Semantics, just facts
To me this means that the fuel air ratio that the carburetor delivers to the engine varies with air density. This means that the carburetor is not altitude compensating. If the carburetor was altitude compensating then the fuel air ratio would be constant with altitude or air density. The key word here is fuel air ratio (fuel/air mixture) not fuel flow.
By the design of the Bing carb, it does not have any component that will adjust the fuel flow to keep the fuel air ratio the same, at different air density or altitudes.
Don
07-03-2012, 10:50 AM
Strange thing about it, although the fuel flow indicates high 7 GPH/hr at higher altitudes, fill-ups indicate an average of 4.5 - 5.0 GPH. I think something may be goofy with the Dynon at 7000' + at DA.
Gary
07-05-2012, 11:07 AM
Same Problem
I have experienced the same problem.
Constant altitude, RPM, fuel pressure, OAT, and the fuel flow changed from 5.3 to over 7 in less than 40 seconds.
Fuel flow actually went as high a 10 with no other changes.
rpm 5300
altitude 7500 ft
fuel pressure 4.3
OAT 57
All with no change in actual fuel consumption.
Gary
07-05-2012, 12:54 PM
That could really pucker ones hiney. Thinking you might have fuel leaking on a hot engine. EYOW!
Larry Vandegrift
ULPower 260is
07-06-2012, 09:16 AM
Originally Posted by BigJohn
.... to Mike just now. Wayne, keep in mind that the fuel system measures flow in between the two pumps, and measures pressure after the two pumps. It is concievable that for some unknown reason the return flow to the tank increases dramatically during this event. Doesn't seem likely, but could explain the high rate of flow.
If you want to see the graph, send me an email at johnpeck@nycap.rr.com.
John
The email to support@dynon.com just came beack as undeliverable, after 4 days of trying. I re-sent it but don't have any confidence it is going through.
John Peck, CFII, A&P, EAA Tech Counselor, Flight Advisor.
?Master Pilot? Award, UFO Member.
RV-12 N37JP 120176 Flying since 2012.
One Week Wonder Build Team, OSH 2018.
VAF paid through 10/2019.
07-06-2012, 09:51 AM
Sent your address
directly to Mike at Dynon, John. I'm sure he'd want to see your plots. The only thing I can think of is that the message is too big for their mailbox.
Sure hope you can get the info to him.
Wayne
