Old 07-04-2012, 02:52 PM
N941WR's Avatar
N941WR N941WR is offline
Default Tip: Cylinder Air Dams
The new baffle kits (You know you have the old baffle kit, if the drawings are hand drawn.) include air dams that get riveted in so as to deflect the air up and over the heads of #1 and #2 cylinders.
The only problem is that they are riveted in place and if you need to adjust them, and you will need to adjust them, you have a problem.
My suggestion is to replace the rivets on the ramps leading to the cylinder heads with flush rivets and platenuts. Then you can make a simple air dam that uses those three platenuts and when you need to adjust the air dams, you can remove them, trim them to size (or replace them, when you trim too much off), and screw them back in place. Remember, that the left and right air dams will be different because the platenuts will be in different places, if you put them where the rivets are supposed to go.
The other option is to forgo the air dams altogether and use foil tape, available at your local hardware store.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 07-04-2012, 07:03 PM
Perhaps a niave question but I'm going to ask it anyway ...
"what is the purpose of the air dam ?"
Old 07-04-2012, 07:09 PM
To reduce the cooling air to the front cylinder(s) and deflect that air to the rear cylinder(s). Say your in-flight CHT's are 340F on #1, 350F on #2, and 380F on #3 and #4. The goal would be to install air dams of sufficent height on #1 and #2 to balance all 4 cylinders at (say) 360F.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 07-04-2012, 07:18 PM
N941WR's Avatar
Or in the winter to block more air to get the CHTs up by putting in taller blockers.
Bill R.
SC86 - Easley, SC
Old 07-04-2012, 07:31 PM
Thanks Kyle.
I wanted to ask the question because I have done several searches lately for "low CHT" and found nothing. My CHTs have almost a 100F separation with the low one being around 260F in cruise and the high one at 355F.
I will be checking plugs, etc. this week but if I find nothing, I will plan to play a bit with air dams.
Old 07-04-2012, 07:36 PM
Thanks Kyle.
You might swap around your CHT probes too. Occasionally you get a bad one. If Cylinder #3 (or whatever) is the high (or low) one and you move that probe to another cylinder and that one becomes the outlier, the probe may be the problem...
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 07-05-2012, 03:05 AM
RV6_flyer's Avatar
I had Superior investment cast cylinders and #2 was the coldest even with the temperature risers. Replaced cylinders with ECI cylinders after 2,200 hours and now #2 is a lot hotter. Removing the temperature riser and it is very close to the other three. #1 still has the temperature riser installed. This is with an O-320 CS.
Note: The ECI cylinders are the through hardened steel barrel just like the Superior was. The Superior through hardened steel cylinders still showed the cross-hatch hone patter and measured out new spec including the choke.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 07-05-2012, 05:03 AM
shuttle's Avatar
shuttle shuttle is offline
Yep, good idea Bill. I did that with mine too. It is especially easy for the horizontal cold air induction engines (the ones that use the snorkel to take air from the No.2 cylinder front baffle ramp) as there is already a need for screws in that area to hold the air filter in place. Though I kept the original rivets and positioned the three screw holes between the rivets. I needed to matchdrill the rivet holes to the flange on the bottom of my air dam then oversize them enough to provide clearance for the rivets. Did likewise on the other side.
Steve
Steve Hutt
West Sussex, UK
RV-7 G-HUTY (not flying yet)
( Tip-UP / TMX-IO-360-M1B / Hartzell 7497-2 / 1x LSE PLASMA III / Dual AF4500's / AF-Pilot AP / 695 )
Old 07-05-2012, 06:32 AM
I just cut my down last week. Took about 1/2" off and it's pretty much evened out the temps.
I was going to pull the baffle off and go this route but Stein Bruch gave me a piece of stainless and said "put this behind it and cut it with a Dremel; it'll be faster."
I could probably cut more down more, but I want to see what winter brings -- assuming that winter ever comes to Minnesota again (it didn't last year).
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 07-05-2012, 06:34 AM
Thanks Kyle.
Fuel injected?
Bob Collins
St. Paul, MN.
