Old 11-01-2011, 08:33 PM
mike in phx mike in phx is offline
It really depends on what you want to do this is not a car turbo kit this is built to work in a aviation world with the stress that means good parts but complete it can be done for $12000 + install but it really depends
Mike Poulsen
Phoenix
RV 6 TURBO
N 694 MP
Old 07-04-2012, 02:45 PM
Default Flying high
So after a lot of testing and running flawlees it was time to run at 17500 feet just to se what i could get for mp at this alt i climed right up there testflight was only one hour
It just runs very nice and fast
Have a good 4th of july
Mike
Mike Poulsen
Phoenix
RV 6 TURBO
N 694 MP
Old 07-04-2012, 10:28 PM
Sig600 Sig600 is offline
13 gph?!
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
Old 07-05-2012, 12:13 AM
rvbuilder2002's Avatar
Default Be Careful.......
20 Kts TAS over redline.
You could be breaking new ground into unknown territory regarding flutter.
If you think not, because of the low indicated airspeed, you should probably read THIS
Old 07-05-2012, 01:09 AM
Default Mike there is a class for you in the AirVenture Cup
ref: www.airventurecup.com. The race this year is from Mitchell, SD to an airport near Oshkosh, then recover at Fond Du Lac(?) and group fly into OSH.
Bob Axsom
Old 07-05-2012, 07:19 AM
Default Air race
Sure sounds fun bob would love to go work will dictate if posible the plane is ready
Fuelflow question how much fuel does a o 360 burn at 2700 rpm with 27.7 mp @ 98% mine takes 13.1
And to all the guys out there i have read about vne and flutter til i turned blue
I do thank you for your concern
We all turn out to be test pilots in the first 25 to 40 hours some of us just keep testing the limits but done the right way
And we will get thru it safely
You just cant find limits on the ground in your hangar and it takes a long time to work up to the most extreme limits
Babysteps til you find your personal limits
Mike Poulsen
Phoenix
RV 6 TURBO
N 694 MP
Old 07-05-2012, 07:53 AM
Mike, I agree with you regarding testing everything performance wise... Except for pushing to the edge of a flutter margin. All professional test pilots know this. With flutter, you can't push to the edge and stop when you start getting close.
It either flutters or it doesn't. If it does, you probably need to just about 100% plan on exiting the airplane.
I also agree that we are all test pilots in the first 25-40 hrs, but there is one big difference... all those hrs are flying within a flight envelope that has been pretty well proven by thousands of RV's having flown 10s of thousands of hours. This high alt., high speed flying you are doing, could very possible be a first for RV-6 to do so. Ever.
In my mind, that makes it quite different.
Old 07-05-2012, 08:06 AM
It just proves vans got it right a very solid platform to build and fly
And again thanks for your concern
Mike Poulsen
Phoenix
RV 6 TURBO
N 694 MP
Old 07-05-2012, 12:15 PM
Heres one just for fun
And then lower alt
Fuelflow is just how much do you want to burn
Mike Poulsen
Phoenix
RV 6 TURBO
N 694 MP
Old 07-07-2012, 03:09 PM
After ajustments to the fuel injectors my egts are alot closer
This is after getting to alt leaning for cruise
Mike Poulsen
Phoenix
RV 6 TURBO
N 694 MP
