Go Back   VAF Forums > The Never Ending Debate Section > Tools
Old 07-02-2012, 02:33 PM
Daniel S. Daniel S. is offline
Default Dimple Dies
Guys.
I have to ask a question... I broke my 3/32" dimple die yesterday. I started shopping around at the normal tool shops. Is there legitimately a difference between a $40.00 "spring back" dimple die set and the plane old $12.00 dimple die from ACS? I can't tell you what kind I've been using for the past 3-4 months because it came in my Isham tool kit. If there is a noticable difference, could you please explain?
DANIEL S.
RV7-A (528KS)
-Empannage Done.
-Electrical System Planning / Schematic Done.
-Wing Kit Delivered 09/13/12.
-Wings 95% Done Flaps & Electrical to go.
-Have got to order the fuse soon!!!!.
[/font]http://www.mykitlog.com/dschoning/
"This is a first-time event, and we're looking forward to it"... Chuck Yeager
Old 07-02-2012, 03:06 PM
FlyingArcher's Avatar
FlyingArcher FlyingArcher is offline
Default Simple Answer
Cleaveland dimple dies are certainly the best you can find.
They produce crisp dimples and let the skin around all flat. I don't have the words to better explain that, but on my skins you can easily tell which dies I used just by looking from an angle with some light. With Cleaveland dies, absolutely no skin deformation is visible while with brand X dies, you can see some waves around.
Daniel Mouly
VAF #778 - [2013 payment done]
RV-9A Emp. & Wings 95%, Fuse 70%
Austin Healey 3000 MKIII fully restored
LFCD (Andernos Les Bains), France
Construction Log comments in French (not really up to date, sorry)
Old 07-02-2012, 08:00 PM
JanRV6UK's Avatar
JanRV6UK JanRV6UK is offline
I will second that .. tried a few different once and Cleaveland at top notch
Jan
Old 07-02-2012, 08:16 PM
GAHco's Avatar
GAHco GAHco is offline
Thumbs up Cleaveland A-OK!
I use their dimple dies and sell them too, the best I have seen.
They are worth every penny.
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
Old 07-02-2012, 08:41 PM
Caummisar's Avatar
Caummisar Caummisar is offline
Default The rest of the story
Originally Posted by Daniel S. View Post
Guys.
I have to ask a question... I broke my 3/32" dimple die yesterday. Thanks
I have some that came from Avery, and others.....but I have to ask..HOW DID YOU break a dimple die?
VAF# 835
RV-7A- Instrument Panel/FWF/Engine Mounted
Slow build --- ALL THE WAY
Victim of SB-632-B
2020 Dues Paid
Old 07-03-2012, 04:35 AM
Randy Hooper Randy Hooper is offline
I broke one once by dropping the male die. I'm more carful now while installing and removing dies in squeezer.
Randy Hooper
RV-8
N84H
Old 07-03-2012, 08:17 AM
Thanks guys. I ordered a die from cleaveland... I'mlsa tool snob anyways . I broke it trying to get fancy dimpling a couple holes I forgot about. It was totally misuse of my tools.
DANIEL S.
RV7-A (528KS)
-Empannage Done.
Old 07-03-2012, 04:25 PM
mculver's Avatar
mculver mculver is offline
I received a surprise tank dimple die in the mail yesterday from Cleaveland. Seems that they were not satisfied with the quality of one that I ordered a few months ago, so they shipped me a new one.
I've yet to use the original die, so I was unaware that there was even the potential for an issue.
That's about as good as customer service can get! And definitely makes paying just a bit more worthwhile!
BTW, the note in the shipment said that this was a very small batch of dies, so not many people got a new one (fewer than 3 dozen).
-- Mike Culver;
RV-9 project sold but details of the build at
www.mculver.com
Old 07-03-2012, 04:53 PM
DCat22's Avatar
DCat22 DCat22 is offline
I saw the ship notice on one for me, but I hadn't picked up the package yet to see the details.
Great way to do business.
-Rick Greer, VAF #2492
Old 07-05-2012, 10:37 AM
clevtool's Avatar
clevtool clevtool is offline
Thanks for the positive comments. Great way to start a day.
The 3/32 die has a small pilot, and our dies are very 'hard' with tight tolerances between the male and female, so they don't tolerate a side load very well. We do replace our dies for free if they break due to normal where, but unfortunately not due to:
<snip>It was totally misuse of my tools.
While gun-shy of even using the term 'tank dies' on the forum, the recent discussion did provoke some testing, which I did by pulling stock dies off the shelf... One dimple and I thought "what the... heck", after over a day of measuring, testing, pulling logs of when we machined what, we found the problem. It seems that after making a custom die for a builder, the numbers in our CNC program did not get returned to the correct measurement. About 200 dies were made with the wrong numbers. Luckily only 30ish were shipped. Those customers now have new males en-route. By contacting customers directly we found "customer zero" where the previous customer had the correct die and the next customer had a bad one. So I think we have the problem nailed down, but make a sample and if your tank die dimples look like they were made with *%%(*'s dies rather than ours, give us a call.
The following photo will show the difference between right and wrong. Notice the straight line reflection from the fluorescent fixture. On the dies that are correct the line continues to be straight across the dimples, where in the wrong example it is bent (because the skin is bent) around the dimpled area.
Mike Lauritsen
Cleaveland Aircraft Tool
800-368-1822
www.CleavelandTool.com
mike.toolman (at) gmail.com
Like on Facebook - Follow on Twitter - See on YouTube
