Go Back   VAF Forums > RV Firewall Forward Section > Alternative Engines
Old 06-26-2012, 07:28 PM
N941WR's Avatar
N941WR N941WR is offline
Default The rotary is dead
Today Mazda announced it was discontinuing production of the rotary engine.
Major bummer on many levels.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 06-26-2012, 07:43 PM
rzbill's Avatar
rzbill rzbill is offline
Yeah, well.. Thats the way I felt when 500CC two strokes went away in GP motorcycle racing.
Bill Pendergrass
ME/AE '82
Old 06-26-2012, 07:56 PM
DaveWelch DaveWelch is offline
Default No more rotary mfg?
Could be a good time to buy all of 'em you can get your hands on?
(I miss my RX7)
Old 06-26-2012, 10:04 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
That is a bit sad after all the money and engineering Mazda put in over the years but there are thousands of engines floating around and will be for many years if you wanted to build one up for a car or aircraft.
The RX8/ Renesis did not do well for Mazda- tons of warranty issues and it was hard pressed to match the fuel efficiency, emissions and power of modern piston engines.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi2.htm
Old 06-27-2012, 12:50 PM
I'd bet it's not that big a deal. They also stopped production on the RX-7 prior to startup on the RX-8/Renesis. They've already got a new version of the engine (with significant changes, including a displacement increase & modified direct injection) at the prototype stage.
Charlie
Old 06-27-2012, 03:53 PM
DCat22's Avatar
DCat22 DCat22 is offline
My first run RX8 is still going strong....love it. I do hope the revisit it....decided not to build a plane with one though. But in the car it's been pretty bullet proof. Just did my big 60K mx....
Oh, and from the article:
the rotary design is notorious for its low fuel economy and high oil consumption
It's designed to burn oil. That's like saying "wheels are notorious for rolling".
Anywho.
-Rick Greer, VAF #2492
Old 06-27-2012, 05:28 PM
roee roee is offline
"the rotary design is notorious for its low fuel economy and high oil consumption"
Um, no...
Wheels are designed for the purpose of rolling. Engines are designed for the purpose of converting chemical energy into mechanical energy.
Rotary engines having high oil consumption is an undesirable consequence of a design compromise. They're designed in such a way that will burn oil, but they're not designed for the purpose of burning oil. There is a difference.
So that quote would be more analogous to saying something like "Brand A tires are notorious for high tread wear".
Anywho.
Roee Kalinsky
San Diego, CA, U.S.A.
RV-7A under construction
www.kalinskyconsulting.com/rvproj/
Old 06-27-2012, 07:05 PM
the_other_dougreeves the_other_dougreeves is offline
The rotary is dead.... long live the rotary.
Interestingly enough, the rotary lives on in the ASK21Mi self-launching glider.
TODR
Doug "The Other Doug Reeves" Reeves
CTSW N621CT - SOLD but not forgotten
Home Bases LBX, BZN
Old 06-27-2012, 07:09 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
The Mazda Wankel rotary engine uses an engine driven pump to meter oil directly into the intake system, for the purpose of lubricating the combustion chamber seals.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 06-27-2012, 07:39 PM
comfortcat's Avatar
comfortcat comfortcat is offline
Actually, the correct quote would be: "V-8 engines are notorious for burning gasoline"
Originally Posted by roee View Post
Um, no...
Anywho.
David Boeshaar
RV-9A - N18TD (reserved) - Fuselage.
"My greatest fear: What if the hokey pokey really IS what its all about?"
TDAircraft.com
-July-
