Old 06-27-2012, 08:44 AM
NovaBandit's Avatar
NovaBandit NovaBandit is offline
Default My DIY camping/cockpit Air Conditioner
With the hot weather about to hit us, I thought I'd share the little portable air conditioner I built to keep myself cool for OSH last year.
It's made out of a 48 quart cooler I had laying around, a heater core I picked up at the local discount auto parts store, a boat bilge pump, and a bilge blower. The total investment was about $60. The heater core is held in place with zip ties and sealed with expanding foam. The blower is just held in place with foam. The pump is screwed and siliconed to the bottom of the cooler.
Not pictured is the 20' dryer vent hose that I attach to the blower.
This is how it works:
The cooler is filled with ice, then a few gallons of water. You can add salt to the water to get an even lower temp, but I never did.
The ice water is picked up by the bilge pump and pumped thru the heater core, then just dumped back into the cooler.
I have the bilge blower set to blow OUT from the cooler, so air is sucked INTO the cooler thru the heater core, cooling it down, then blown out the blower thru a 4" dryer vent to wherever I want the cold air directed. The gray box next to the blower on the lid of the cooler is a motor controller I was playing with to control the fan speed. It's not really needed.
Splice the pump and blower motor into a 12v power source and you have a few hours of nice chilly air. It was effective enough to keep me cool in a pop-up camper at OSH, and I'm sure it would cool a cockpit down quite nicely!
I'm going to pull it out of storage and try to keep myself somewhat cool in the garage. It's not going to cool the entire garage, but it'll feel nice to have it blowing directly on me!
Ed Kranz
RV-10 N829EC - Flying
First Flight: 8/29/15
KSGS - Fleming Field, South Saint Paul, Minnesota
YouTube.com/GoodPlaneLiving
-- Build Timelapse and Travel Videos . . GoodPlaneLiving.com -- Build and Travel Blog
Old 06-27-2012, 09:38 AM
billnaz's Avatar
billnaz billnaz is offline
Default Great job of scrounging!
I can see this project in my future. Great cheap cockpit precooler. Have you seen the price of the commercially available products? Big savings, good job!
Bill Grischo, Gilbert AZ
N911WG RV-6A DVT
Flying, thinking about polishing
Old 06-27-2012, 09:51 AM
larrynew's Avatar
larrynew larrynew is offline
Built one too and it works surprisingly well. Being able to seal the intake (3" knockout plug) helps the ice last when it's not in use.
Longer hose on the discharge side helps by allowing you to drain the cooler without taking it out.
Here are more details if you're building one: http://larrys-airplane.blogspot.com/...ditioning.html
Larry New
RV-7A - Built, flying 900+ hrs
RV-10 - Built, flying 2.9 hrs
??? - RV-12, Subsonex
48 States in 7 Days!
VAF Paid - Annual Autodraft
Old 06-27-2012, 09:52 AM
Phlyan Pan Phlyan Pan is offline
How much does it weigh full? I need to put this in my W&B spreadsheet.
Old 06-27-2012, 09:56 AM
NovaBandit's Avatar
Not sure, but it's just a cooler full of ice and some water. You can even keep your drinks cold in there.
Ed Kranz
Old 06-27-2012, 09:58 AM
NovaBandit's Avatar
Good call. I use a piece of 2" pink foam board to plug the heater core when I'm not using it.
Ed Kranz
Old 06-27-2012, 10:30 AM
longranger's Avatar
Originally Posted by NovaBandit View Post
...You can add salt to the water to get an even lower temp, but I never did. ...
I don't know for sure, but I'd think salt water would be a bit hard on the heater core (corrosive). Antifreeze would work better, but it's expensive so you'd want to come up with some way of reusing it.
RV-7 TU 904KM (reserved)
Construction Log
Old 06-27-2012, 11:49 AM
DCat22's Avatar
DCat22 DCat22 is offline
I'm building something like this for my office....
Although the radiator is external, and from stuff used in computer watercooling. Same basic concept though. (A http://koolance.com/radiator-4-fan-1...r?path=0_54_93 with four fans on the back.)
-Rick Greer, VAF #2492
Old 06-27-2012, 12:58 PM
JDRhodes JDRhodes is offline
The heater core is probably 20 bucks. When it rusts out - get another one.
I have Cub Scout Camp duty coming up next week and will be spending 4 days in a tent in 95 deg heat. This might be a good project for the 4th of July holiday!
Need a solar charger to replenish the battery during the day.
Jeff Rhodes - Taylorsville, GA
RV-9, 7 - going fast
BC-12D - going slow
jrhodes@v1salesmgt.com
Old 06-27-2012, 01:04 PM
NovaBandit's Avatar
The deep cycle battery I had in my camper lasted me all week in Oshkosh, although it might not be the most practical thing to bring on a camping trip.
Ed Kranz
