Old 06-23-2012, 03:21 PM
danbenua danbenua is offline
Default New Camera, First Video
The wife gave me a GoPro Hero2 for my B-day, so I went out to try the
head-cam mount in the RV-3B. The result was a minor headache, and
this video: http://www.youtube.com/watch?v=nOVMBS1aBfc&feature=youtu.be
- Dan Benua
Hillsboro, OR
Old 06-23-2012, 03:37 PM
rvaitor87 rvaitor87 is offline
Default First Vid
Don't ya just love the -3! effortless to fly and do aerobatics!!
Taz
Mike Bauer
Technical Counselor
EAA 229 President
RV-3 flying
RV-4 building
Old 06-23-2012, 04:18 PM
YellerDaisy's Avatar
YellerDaisy YellerDaisy is online now
Very Nice!!
JD
RV-4 - 160HP O-320 - Sensenich GA
RV-3B - O-320 - "Daisy" (sold)
http://jdfinley.com
Old 06-23-2012, 04:42 PM
Don's Avatar
Don Don is offline
If that's you're first attempt I hope you keep it up. Nice plane, nice video, well above average editing.
Don Alexander
Virginia
RV-9A 257SW Purchase Flying - O-320, Dynon D100
RV-9A 702DA (reserved) Finish Kit IOX-340
www.propjock.com
Old 06-24-2012, 07:36 AM
f14av8r's Avatar
f14av8r f14av8r is offline
Default Nice Video
Nice Video and a great looking plane!
You know, we all need to collaborate though and figure out how to keep the prop from looking so stupid in these videos. I'm sure it has something to do with frame rate but I'm yet to see a solution posted.
Nice work!
Old 06-24-2012, 05:05 PM
Neil Rob's Avatar
Neil Rob Neil Rob is offline
Default Go Pro camera
I bought one of these a couple of months ago- The the demos I watched were all from the same camera angle as initially set up,- and most times boring!
I purchased a small electric motor with a reduction drive kit included to rotate the camera, and, so vary the viewing.
The ratios were 1:4, 1:4, 1:4,---, with six gears included and finally giving about about 3 rpm. from the initial multi thousand at the motor.
I drilled one of the mounting pads included with the camera kit centrally to take the extended final reduction drive rod (3mm) and turned a small plastic disc to press onto the last small reduction cog (6mm)and hot glued it to the underside of the Go Pro Mount.
The motor kit has one hole drilled to take the clamp screw of the go pro kit.
The $3 battery pack has two 1.5 volt AAA's and a on/off slide switch.
The reduction and motor kit $15. Time to make - one hour. Time to think 2 hours! No change to to Go Pro Kit.
Bought a switch to reverse the motor so the view can be changed from ahead, round 180 deg. to pilot/driver, stop, hold, and reverse back to ahead, or view out the side of aircraft, racing car, boat ,what ever.
One problem is the transmission of the motor noise up the drive gear chain, but a external mike would eliminate this. The prop problem mentioned is beyond me!
Will send pictures to those interested. The camera is a superb little unit, and I have mounted it on my cnc mill while making traction engine and RV-3 parts.
Old 06-24-2012, 08:42 PM
RWoodard's Avatar
RWoodard RWoodard is offline
Default Pic and Parts Number request
I'm sending you a PM with my email address.
Thanks!
Rod Woodard
Brighton, Colorado (CO12)
RV-3 N87CT (Thanks Chuck!)
Glasair 1RG N388DM
RV-3 N99RV sold 01/2000
F1 MkIII empennage?arrived 08/22/2018--collecting dust
Old 06-24-2012, 10:54 PM
loopfuzz's Avatar
loopfuzz loopfuzz is offline
Dan, Thats a great paint job!
RV6
Maule M5
Old 06-25-2012, 08:17 AM
carlrai's Avatar
carlrai carlrai is offline
Default Great Job editing
Dan,
Nicely done. Look forward to catching it on a larger screen when I get home.
My frustration with YouTube has been uploading video with background music. With each attempt, the music is deleted and for the life of me, I can't figure out how you and others get the music to play.
If you have a moment, would you (or maybe other readers) mind giving me a rundown on how you accomplished getting the music accepted by YouTube?
Thanks - Really nice job on the video and the "3" is gorgeous.
Carl Raichle
Lutz, FL
RV-9A N194CR
RV-14A Under construction
Based at KZPH
AA4SR
Old 06-25-2012, 07:42 PM
JoeBlank's Avatar
JoeBlank JoeBlank is offline
Nice video Dan! Even the music played just fine...
Joe Blank
RV-6
IO-320-D1A
Advanced Flight Systems
Van's Aircraft Inc. Technical Support-Retired
EAA Tech Counselor & Flight Advisor
www.westcoastravens.com
