  #611
Old 06-12-2012, 12:58 PM
RVG8tor's Avatar
RVG8tor RVG8tor is offline
Default Skirt and WS done
Yesterday I declared the skirt and Windscreen done! The skirt has a slight low spot at one rivet but I will let the painter handle that, we talked and he said to get it close so I hope this works. I also have 5 or 6 pinholes mostly at the edge of the WS layup. This turned out much better than I had hoped. Thanks for all the help from VAF members getting me to this point. A year ago glass work totally intimidated me.
Cheers
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
KOCF
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2021
Old 06-12-2012, 01:17 PM
Matt Dralle's Avatar
Matt Dralle Matt Dralle is offline
Cheers
Wow, that looks fantastic! What did you use to fill the skirts?
Matt Dralle
RV-8 #82880 N998RV "Ruby Vixen"
http://www.mattsrv8.com - Matt's Complete RV-8 Construction Log
http://www.mattsrv8.com/Mishap - Landing Mishap Rebuild Log
http://www.youtube.com/MattsRV8 - Matt's RV-8 HDTV YouTube Channel
Status: 172+ Hours TTSN - Rebuilding Fuselage After Landing Mishap...
RV-6 #20916 N360EM "The Flyer"
http://www.mattsrv6.com - Matt's RV-6 Revitalization Log
Status: 100+ Hours Since Purchase - Upgrades Complete; Now In Full Flyer Mode
N8RV's Avatar
N8RV N8RV is offline
Nemo, you might consider rounding off that sharp corner on the canopy skirt. When the canopy is open, it will stick out and I can just see myself walking into it causing myself an ouchie. It might just be me, but when all of your plane's admirers crowd in to take pics of your panel, somebody might get snagged.
Just a thought. Looking good!
Don McNamara
Peoria, AZ
Builder: RV-8 "Smokey"
Old 06-12-2012, 04:17 PM
RVG8tor's Avatar
Default filler
I filled the rivet hole centers with JB weld then went over with a mix of FLOX, which filled some. I then used some West system 407 filler, I went with West because I bought all the stuff before I became smarter on how to get cheaper stuff. When I set the rivets they were dipped in epoxy, to keep them from loosening up. One thing suggested is to lay a layer of thin cloth over the rivet line. I considered this but, at this point I want to get flying, I will re-visit that idea before it gets painted.
Lastly I rolled on two coats of clear resin with a foam roller, letting first layer get just past the tacky stage. Aft this set I sanded smooth, I was planning to roll on one more layer and then squeegee it off (I did this on the windscreen) but I liked what I had so I primed everything.
I did also heat up the rolled on layer with a hair dryer, I read on this site that this helps bubbles from the roller open up. It does seem to do the trick. The skirt really did not take much to fill. The windscreen I used west 407 filler for most of that work. Once it was to shape I used the clear resin technique.
The nice part of rolling it on like DanH pointed out in one of his write ups, is you get a rough sort of finish that makes it easy to see how much more you need to sand, if it's still shinny you need to sand more.
Mike "Nemo" Elliott
KOCF
N800ME
Dues Paid 2021
Old 06-21-2012, 09:58 AM
RVG8tor's Avatar
Default Move to Airport
Well after 5 years my plane has left the nest, well sort of. I made the move to the airport. The move went very smoothly. I have moved all the tools and started to organize the hanger so I can get back to work.
Cheers
My yearling horse observing things (above the truck)
Kind of looks like we are working at cross purposes
I can see in this photo why my wife complains my jeans are too loose!
Mike "Nemo" Elliott
KOCF
N800ME
Dues Paid 2021
Old 06-21-2012, 10:49 AM
panhandler1956's Avatar
Good going Mike!
It's all down hill from here!
Can't wait to see it fly!
Brent Owens
Columbus, OH
RV-8 'Contrary Mary' flying
N784DE S/N #82614
www.fixedwingbuddha.com
Follow me on Facebook
Old 06-22-2012, 09:35 AM
polishpilot's Avatar
polishpilot polishpilot is offline
Cheers
Always good to hear someone is "movin on up". Good work on the progress, Mike. I am hoping for next Spring to move over to the airport. See you around.
N96LV
RV-9A started April 2011
Flying May 2014
Sold Oct 2014-Not one of my best decisions
2021 Dues Paid
Old 06-23-2012, 02:52 PM
Tilford's Avatar
Tilford Tilford is offline
Default Great Going!
Great work, Mike. I'm looking forward to hearing about your first flight. More inspiration for me.
Take care,
Greg
Old 07-05-2012, 11:14 PM
N546RV's Avatar
N546RV N546RV is offline
Hey, that looks like an airplane part!
Of course, the instructions say nothing about clecoing the two h-stab halves together at this point, but I don't let that stop me from doing it just so I can cackle a bit and get a good lok at where I'm going.
Philip
-8 fuselage in progress (remember when I thought the wing kit had a lot of parts? HAHAHAHAHA)
http://rv.squawk1200.net
Old 07-06-2012, 07:48 PM
KMinor's Avatar
KMinor KMinor is offline
Default Obligatory Empennage Picture
Just finished the vertical stabilizer tonight. My kit came in while we were in the hospital having the baby in February. Work and kids keep me busy so building is slow, but I'm on the pay-as-I-go plan and not in any hurry.
