  #11
Old 06-18-2012, 06:57 PM
Flyin'Bryan's Avatar
Flyin'Bryan Flyin'Bryan is offline
Default BEEEEEEEEEEERRRRRRR!
Originally Posted by 339A View Post
I plan to bring a case with me to OSH maybe two, if I can get Bryan Raley aka "The Mule" to agree. We'll be in HBC all week stop by and if there is any left you're more than welcome to have one.
Scott
Hah! And I thought you were going to pack your cooler full of ill-fitting-in-airplane essentials, like tents and chairs and such!. Of course you realize that I might just have to apply that special pre-prohibition transport tax for this little favor, or perhaps if your supply ends up being minus one or two bottles by the time you arrive at KOSH, that might be sufficient as well.
On a more "related-to-thread" note - I am jotting this one down in my "future-to-do" list. Nice adaptation, and not bad for a POS from China! I even half understood the Chinenglish instructions - no doubt from much past experience.
Bryan Raley
http://bryansrv8project.blogspot.com/
Building RV8
EAA Chapter 301
CFII/MEI, ATP
SportAir Workshop Graduate x 4: Sheet Metal, RV Building, Electrical, and Composite classes.
Tail Wheel Endorsement Completed
Empennage done, Wings in progress, N462AK reserved.
Old 06-18-2012, 08:55 PM
339A's Avatar
339A 339A is offline
Default Beer Runner Fees
Well there will be some ill fitting airplane essential items to be carried. As with any good rum running business you need a legitimate cover for your contraband. Making sure that the "transport tax" is paid will be of the utmost importance.
I see in another thread that Pete Howell now has access to "Moonshine". This could lead to a possible expanding of the business... just a short hop over to Tennessee.
Thanks as always Bryan,
Scott Mills, Front Range, CO
N339A - 1900 Hours!! since 9/11/05
Like Us on Facebook: https://www.facebook.com/ScottandDeb...tures/timeline
Airport Landings
"In order to discover new lands one must have the courage to lose sight of the shore." Andre Gide
"Never feel sorry for a man who owns a plane" Charles Morse (Anthony Hopkins) in The Edge
Old 06-18-2012, 10:10 PM
Phil's Avatar
Phil Phil is offline
Good info Scott. I'm ordering one, because the Costco scope is the real POS. I have one and hate it.
Just curious... Are you running ROP? From the images, that would be my guess.
Old 06-19-2012, 05:21 PM
339A's Avatar
It would certainly be correct to say I run ROP. Even though I have a GRT EIS I have never had any success getting it to a LOP condition. It's a carbureted engine. Typically I just lean to roughness then crank it in two turns.
On another note, I did locate some "Free" camera software that seems to work OK with the camera. It is easier to use and works better than the supplied Chinese dental software. It is called Debut Video Capture software.
At my next oil change I plan to do a through camera inspection of all cylinders. When I get that done I will post it here and see what the engine experts think of my internals....
Regards,
Airport Landings
Old 06-19-2012, 06:36 PM
Mile High Relic Mile High Relic is offline
It would certainly be correct to say I run ROP. Even though I have a GRT EIS I have never had any success getting it to a LOP condition. It's a carbureted engine. Typically I just then crank it in two turns.
I'm certainly no expert on this, but there was a EAA webinar on leaning just last Wednesday. I'm sure you could find a recording, but Mike Busch said you should lean to roughness and then richen the mixture just until it runs smooth, and that's it.
I thought it was a pretty good webinar, but I generally like all the ones he puts on.
The dental camera you found looks great. I may have to talk to my A&P into getting one.
Old 06-19-2012, 08:04 PM
bhester's Avatar
bhester bhester is offline
Cool I'm about to order this one
What about this one:
http://www.ebay.com/itm/NEW-6-LED-De...32856630324636
It was talked about a few weeks ago in another thread.
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
Old 06-19-2012, 09:22 PM
erich weaver's Avatar
I ordered and received that very same one. When I tried to load the software/driver for it, I got a virus detection warning. I bitched to the seller and he said to ignore the warning. I wasn't willing to do that, so he sent me a mini DVD with the software to load. Same problem, and he again advised to ignore the warning. Big runaround and I finally demanded my money back, which I eventually did get.
Proceed with caution and make sure you at least have up to date virus detection.
erich
Old 06-19-2012, 11:24 PM
az_gila's Avatar
az_gila az_gila is offline
Thumbs up
Originally Posted by Mile High Relic View Post
.....but Mike Busch said you should lean to roughness and then richen the mixture just until it runs smooth, and that's it.
Which is exactly what the instructors taught in the 70's before anyone had any sort of engine monitoring instruments....
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 06-20-2012, 05:36 AM
which is exactly what I am doing in the 21st century without fancy engine monitors
Old 06-20-2012, 12:02 PM
Space Cadet's Avatar
Space Cadet Space Cadet is offline
Default Lighting?
Thanks for the tip Scott. I'm with Phil, I can't get the Costco one to work worth a **** so far.
Did you add any external lighting sources for those samples you showed, or was it all from the camera?
Dwight
RV-10 #40762 - 100 hrs+
Denver, CO
