Old 06-17-2012, 08:11 PM
RV6AussieNick RV6AussieNick is offline
Default RV-6 Elevator deflection angles
Hi Guys,
I'm pulling my hair out trying to find some info on elevator deflection, i've searched the VAF and found a couple of mentions on 23-25 deg angles of defection, i've just spent the past few hours poring over my drawings and manuals trying to find anything that i can use.
I haven't fitted the Hori stab to the aircraft yet, doing a bench rig just on the defection before i drill the elevator horn holes.
Can some one point me to a drawing or rigging instructions.
Nick Purcell
Licensed on B767, A330 Eng/Airframe
Fixing up RV6, building a Stewart S51
Basically a major overhaul of everything.
Old 06-17-2012, 08:37 PM
it's in the flight-testing section of the manual.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 06-17-2012, 08:38 PM
Pat Hatch's Avatar
Pat Hatch Pat Hatch is offline
Page 15-1 of the manual has a chart that reads as follows: Elevator, maximum up/down = 30/25; minimum up/down = 25/20. (Degrees)
So there is some leeway and as I recall there is no reason to vary from these numbers.
Hope this helps.
Pat Hatch
RV-4 (Gone to RV heaven)
RV-6 (N44PH - Flying)
RV-7 (Sold)
RV-8 (Builder & Avionics Installer)
www.phaviation.com Trim Relay Boards/Flap Actuators
www.pathatch.com/blog (Photography)
Track Me
Old 06-17-2012, 08:55 PM
Mel's Avatar
Mel Mel is offline
UP....25-30?, DOWN....20-25?
If you plan aerobatics, I recommend that you strive for the max limits. i.e. 30? up and 25? down.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 06-17-2012, 10:17 PM
Default Thanks
Thanks for the heads up guys, i looked in the flight testing section and didnt see it, i have a 20yr old manual so i guess its not in there are a few other things i have found.
Nick Purcell
Old 06-17-2012, 11:56 PM
az_gila's Avatar
az_gila az_gila is offline
Smile Control Limits
It's in my over 20 year old, still typewritten, manual on page 15-3.
If you don't have the elevator numbers, then you probably don't have the rest -
Elevator
Down 20-25 Up 25-30
Aileron
Down 15-17 Up 25-32
Rudder
Left and Right 30-35
Flaps
40 down - Design Limit - no minimum number given.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 06-19-2012, 10:16 PM
Default Great help
Thanks for the other info Gil,
So far i have found a few pages missing from my manual, mainly Fig pictures and a bit of text.
Nick Purcell
