Old 06-10-2012, 09:52 PM
Phil's Avatar
Phil Phil is offline
Default AFP Purge Valve Photos
Can some of you post some photos of your purge valve with the cable control attached?
I was looking at mine closely today and the valve is clocked in a way that I have to push for cut-off and pull for rich. Exactly the opposite of what we want. Looking at my setup closely, I can't see any way to re-route the cable and re-clock the arm in a way where you pull-to-lean.
If you can post a pic of your setup, I'd appreciate it. I'm sure I'll have to make some modification to make it work correctly.
Phil
Old 06-11-2012, 03:47 AM
rleffler's Avatar
rleffler rleffler is offline
Phil
I would give Don a call. Surely you aren't the first to run into this. I still have to do this too. I'm finishing the fwf right after I finish the cabin cover.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 06-11-2012, 06:07 AM
Walt's Avatar
Walt Walt is offline
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 06-11-2012, 06:16 AM
Phil
I sent my unit back to Don for a reorientation of the valve lever. It came back the way I wanted it. Pull for OFF, Push for ON with a straight shot at it from the fire wall through the aft baffle.
Otherwise you have to run the cable around the front or side of the unit to get what you want. That is not necessary, the valve can be changed to get what you want.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 06-11-2012, 09:53 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
I dont have a photo of it, but my installation is very similar to what Walt shows.
I think it is also a good idea to have a spring installed to keep the valve open, if the push/pull cable or its mounting components fail.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 06-11-2012, 01:58 PM
N427EF N427EF is offline
I suppose you could send the purge valve back to have the arm reoriented but most installations I have seen are like Walt's or mine.
Walt used what appears to be a mixture grade cable with a threaded end,
probably the best choice.
Ernst Freitag
RV-8 finished (sold)
RV-10 Flyer 600 plus hours
Running on E10 mogas
Old 06-11-2012, 02:16 PM
Walt's Avatar
Do you have springs on your throttle and mixture ??
Old 06-11-2012, 02:28 PM
Mike S's Avatar
Senior Curmudgeon
Nope, but them I am using a higher quality cable for them. And they do get a lot more use than the purge valve, which I use only once a flight.
My purge valve is operated by a much simpler wire-in-a-cable setup, and a pinch connector at the arm.
As I recall, the good folks at AFP do recommend a spring.
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 06-14-2012, 07:21 AM
ecurington ecurington is offline
Default Precision Fuel System W/Purge Valve
Anyone installed the airflow purge valve with the Precision EX fuel system? I just noticed the orientation of the fuel divider is significantly different between the Airflow and Precision setups. I was just going to order the purge valve bracket from airflow, but from the posted pics, it does not appear that will work. Looks like I will need to manufacture my own bracket for the purge valve.
Anyone got pics of a precision fuel system with airflow purge valve?
Eulice Curington
RV-10 Building
