06-10-2012, 10:06 AM
have done some preliminary troubleshooting which "to me", would normally include checking pressures, making sure there are no obstructions,
I agree that blind internet troubleshooting is not optimal but when stumped posing the question to a broad audience may generate some not heretofore thought of options.
I was surprised when my filter clogged how many "builders" ,including
myself, and A&P/IAs where unaware of the filter.
Unfortunately early in the process of clogging fuel flow and fuel pressures were within normal limits.
Milt Concannon
06-10-2012, 10:20 AM
Check fuel vents for insects
Have a look inside the fuel vents
06-10-2012, 10:43 AM
Switched tanks. Checked flow. Changed mechanical pump. Checked vents. No flop tube. Airframe is an early 7a.
Based on everything we know so far it just about has to be firewall forward and fuel related. But I was not aware of a pre controller filter, nor morning sickness. Thank you all for the assistance. And we're still open to suggestions.
06-10-2012, 10:54 AM
The LYCOMING stuck valve issue usually occurs after 600 hours, according to LYCOMING. I had this issue on an o360. It felt like the engine ws going to come off the mounts. Once cooled down everything was fine. After happening twice I used the service bulletin to address the issue. Here is the link. http://www.lycoming.com/support/publ...fs/SI1425a.pdf
Bill Peyton
RV-10 - 1125 hrs
N37CP
First Flight Oct 2012
Aviation Partners, LLC
06-10-2012, 03:35 PM
Just heard from our friendly A&P. He was aware of the fuel controller filter and cleaned and checked it, along with the the others. Evidently that's where he disconnected the fuel line and measured that the pump ( and the mechanical pump plugs out and using starter) would put out about 50 gallons an hour.
The pilot described the problem as an abrupt power loss, with the engine going to a low rough idle. Morning sickness or ??? can do that? And the pilot said the gauges all seemed to read normal???
The A&P is considering taking the spider off and sending it to Don for overhaul.
06-10-2012, 05:13 PM
Doc, Get the Airflow Performance manual out and look in the troubleshooting section. I still bet you have an air leak in the system. Don
RV 7 N212MD Flying as of 12/22/2007
Backcountry/TCOW Super Cub flying 03/12/2011
Next project?
06-11-2012, 02:14 PM
Sticking valve/morning sickness (which involves one cylinder 99.9% of he time) isn't going to take you idle, as described in the initial report.
As for Internet troubleshooting, if it's so questionable, then why does anyone read or post here in the first place? Obviously, you have to take things read here with a grain of salt and do your own cross checking. I had a nagging, chronic (minor) engine problem that went on for years solved with Internet troubleshooting. Sure am glad I asked!
06-11-2012, 04:57 PM
I misread the original post, I thought he pulled it it idle. I agree, a sticking valve would not cause the engine to go to idle.
Bill Peyton
RV-10 - 1125 hrs
N37CP
06-11-2012, 05:32 PM
Why do people post, because folks like to speculate on things and it's "fun" to try to guess whats wrong (anybody can do it, no experience required  ).
However, troubleshooting is about solving a problem by going through a detailed step by step, logical, process of elimination.
About all the info given in the first post was my engine is cutting out and now I'm baffled, can you help. So I would suggest that if you are looking for good focused ideas then you need to provide very detailed information:
1) Specifics about the equipment involved (mags, FI or carb etc)
2) Recent work/repairs (when is the last time the plugs were cleaned for example)
2) How many hours on equipment (new low hour engine/ovh'd 3 times etc)
4) Exactly what things that have been done to try to solve the problem
5) Symptoms - did it start all of a sudden, getting worse, temp related etc.
6) Instrument readings such as EGT/CHT/fuel/oil/pressures/volts/amps etc.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
06-11-2012, 05:34 PM
To the unintiated though it may "feel" like it went to idle due to such a sudden loss of power.
