Old 06-11-2012, 02:12 PM
N8RV's Avatar
N8RV N8RV is offline
Default Coax cables to coils
Another thread discussed the importance of having good, solid connections from the coax to the coils if you have a Lightspeed Engineering EI unit, which turned out to be an issue for me recently.
I had just returned from escorting the RV-1 to Lee's Summit and landed uneventfully. Put Smokey to bed without even cleaning off the bugs. I went out on Thursday for a quick flight around the patch (and clean off the bugs afterward, naturally) and was quite surprised when I did my run-up to find that the engine power dropped very dramatically when I turned off my left mag and ran on the LSE only.
I taxied back and pulled the cowling to change the oil and cogitate what could possibly have caused the lack of power. After all, LSE had just repaired and updated my Plasma II+ unit about 50 hours ago.
After changing the oil and filter, I started with the LSE unit and worked toward the engine. All seemed fine until I got to the connection of the coax to the coil -- the center wire was broken! Broke right at the crimp connector.
I stripped the center lead and crimped on a new connector. I decided to check the other connector as well and did no more than just touch the lead and the wire broke!
I had routed the coax around the center baffle support bracket to the right, then looped it back behind the coils, making a pretty sharp curve with the coax. There is obviously enough vibration when the engine shakes to have fatigued the center conductors where the connectors are crimped. I have reinforced the connector area with some sensor-safe RTV until condition inspection. Then I will re-route the coax cables and bring them DIRECTLY through the baffle and into the coils with no curves.
As a first-time builder, these are the kinds of things that are not second nature. With something as critical as electronic ignition systems, having a wire break due to vibration is not a good way to learn. Take a look at your installation -- if your coax cables make bends anywhere near the connectors that plug into the coils, you would be wise to either re-route the cables to eliminate the bends or reinforce and support the coax-connector interface.
Hope that makes sense. I didn't think to take any pics of my installation or the problem might have been evident to an experienced builder.
Don McNamara
Peoria, AZ
Builder: RV-8 "Smokey"
Old 06-11-2012, 02:37 PM
Kahuna's Avatar
Kahuna Kahuna is offline
This is most notable seen on..
1. Use of coax that is not RG-400. Where the center conductor is not braided wire but solid core. Very bad
2. Installations that have not provided the proper strain relief.
3. Improperly crimped fast on (too tight or too loose)
4. Tinning the center conductor braid. (Bad in a high vibration environment)
As a technique when ever your doing your fwf poke around, and your grabbing everything, be sure you are grabbing those coax wires too.
Kahuna
6A, S8 ,
Gold Hill, NC25
Old 06-11-2012, 03:12 PM
N8RV's Avatar
The center conductor is braided, so it must be RG-400. When I re-do the installation through the rear baffle, I'll be thinking of a way to protect that fragile point where the rigid insulator over the center conductor meets the crimp-on connector -- that's the weak link and the focus of vibration.
There has to be a way to make that union RIGID to protect that center conductor. I'll think of something ...
Don McNamara
Peoria, AZ
Old 06-11-2012, 04:16 PM
DanH's Avatar
DanH DanH is offline
Adhesive heat shrink.
Dan Horton
RV-8 SS
Barrett IO-390
Old 06-11-2012, 04:27 PM
Mel's Avatar
Mel Mel is offline
Default Not Necessarily!
Don't assume too much. Many quality coax cables use a stranded center conductor.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 06-11-2012, 04:35 PM
molson309 molson309 is offline
Generally RG-58 has a black outer jacket and RG-400 has a translucent, brownish jacket. Very distinctive. Some RG-58 has a stranded center conductor so you can't go by that.
Mark Olson
RV-7A First flight 2005 Sold 2019
F1-EVO Rocket First flight 2010
Old 06-11-2012, 04:36 PM
Lars Lars is offline
For starters, RG400 usually has a translucent copper-colored outer insulation. RG58 (at least the stuff I've seen) is generally black. And then there's the solid vs. multi-strand center conductor.
That said, I test-drove a bunch of crimp connectors on sample pieces of RG400 before committing to the real thing. I didn't like any of the results, so I grafted pieces of tefzel wire to both the center conductor and the braid, then terminated the tefzel wire with crimp (Fast-On) connectors. The tefzel wire is much more flexible and allowed me to create service loops for strain relief in a small area. Much nicer.
Oh yeah, and what Dan said: adhesive-lined heat shrink everywhere.
Edit: I see Mark beat me to the RG400 description. Glad to see corroboration, I'm just waiting for someone to write that RG58 (or RG400) is available in chartreuse of some other designer color
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
960+ hours as of June 30, 2020. Where did the time go?
Old 06-11-2012, 04:47 PM
Finley Atherton Finley Atherton is offline
Not sure what type of crimp connector you are using but make sure you use a crimp connector with the extended metal sleeve that is designed to crimp on to the insulation surrounding the centre conductor AND the centre conductor. This connector requires a double crimp ideally with the correct tool so that both the centre conductor AND the insulation surrounding the centre conductor will be crimped. IMHO the crimp connector supplied with my Plasma III was inadequate as it only crimped the centre conductor.
Fin
9A
Old 06-11-2012, 08:04 PM
Dan Langhout's Avatar
Dan Langhout Dan Langhout is offline
Default PIDG (Not)
Originally Posted by Finley Atherton View Post
<snip> IMHO the crimp connector supplied with my Plasma III was inadequate as it only crimped the centre conductor.
Fin
9A </snip>
Second that. My Plasma II+ came with two yellow crimp connectors (for the shield wire) that appear to be genuine AMP PIDG. It also came with two red connectors (for the center conductor) that appear to be something else. I ordered some of the fully shrouded red AMP PIDGs to use instead.
Dan Langhout
2020 =VAF= Dues PAID . . . . .
RV-7 N528DP slow build
First Flight July 26th, 2014
665 hours and counting . . . .
Now based at Moontown (3M5)
Old 06-13-2012, 01:09 PM
G3i Ignition's Avatar
G3i Ignition G3i Ignition is offline
Default RG400 ends
I use RG400 coax along with my ignition system. In my G3i installation manual pg. 24 shows a example on how to assemble terminal ends with crimp/heat shrink terminals to re-enforce the connection. Link:http://www.g3ignition.com/s1s2_manual.pdf
Thomas Shpakow
http://www.G3ignition.com
Follow G3i on Facebook.
www.facebook.com/pages/G3i-Ignition/243104229291
