Old 06-08-2012, 12:02 PM
DocThrock DocThrock is offline
Default RV-7A engine near failure?
My buddy has a 7A with 180, cs, AFP pump, filter and injection. He took off relatively cold and the engine went to rough idle shortly on climb out and he made a safe landing. On touch down, then engine caught up and ran perfectly.
Test flight. No problems up to 8K altitude (from 580 Ft). This time, on pitch over, the engine did the same thing. Mags, fuel selector, boost pump, no effect. Negative Gs, positive Gs, hard banking, no effect. No frank indications on any gauges. Had to land again at rough idle. Got on the ground, tapped the brakes, engine caught back on and ran fine.
His A&P is baffled, and so am I. Any ideas?
Thanks!
CONCLUSION: Turned out to be contamination beyond the filter screen inside the Airflow Performance fuel controller. Some fibers had evidently slipped through the pores in the filter and clogged the inlet. When you pulled the filter out, nothing was in it. Up inside where it seated, a glob of clog blocked the fuel flow. The controller had to be completely disassembled (by Don @ AP) and returned to service. Very weird. No signs of any debris ANYWHERE in the entire fuel system. Hopefully pictures are forthcoming.
Last edited by DocThrock : 07-04-2012 at 11:13 AM. Reason: Engine starvation problem solved.
Old 06-08-2012, 12:19 PM
attson attson is offline
How about checking the engine air intake to make sure there is plenty of air for proper fuel burned
Old 06-08-2012, 12:26 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
New plane?
Has anything been worked on since it last operated normally?
Don Jones's Avatar
Don Jones Don Jones is offline
Default Hours?
How many hours on the engine?
Sounds a lot like the classic Lycoming sticky valve guide to me.
Don Jones
Technical Support Manager
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
Old 06-09-2012, 09:45 PM
yakdriver yakdriver is offline
Does he have the purge valve. Make sure all the fittings from the purge valve back are tight and there are no cracks in any of the flare fittings that would allow air in the system. I had the same thing happen on mine after I had the baffle off and I had only finger tightened the purge valve fitting. Don
RV 7 N212MD Flying as of 12/22/2007
Backcountry/TCOW Super Cub flying 03/12/2011
Next project?
Old 06-10-2012, 12:15 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Thanks!
There is a story here, ----- what is the common feature that landing will effect.
I would look closely at the fuel system.
Is there anything in the fuel tank floating around that could block the pickup???
Is there a flop tube than could be in the wrong position??
I have seen the same symptoms in a R/V aircraft that had the fuel pickup in the wrong location.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 06-10-2012, 07:17 AM
Walt's Avatar
Walt Walt is online now
I would have to agree with Don, sounds like typical Lycoming "morning sickness".
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 06-10-2012, 07:40 AM
N395V's Avatar
N395V N395V is offline
Just as the fuel line enters the AFP fuel controller there is a very small very fine filter. If it is starting to get clogged it will cause those exact symptoms.
It should be pulled and cleaned at every oil change.
Milt Concannon
Old 06-10-2012, 08:01 AM
Walt's Avatar
This why I don't like to do blind "internet troubleshooting".
Doc said in his first post that he and his A&P are baffled, this would lead me to "assume" that they have done some preliminary troubleshooting which "to me", would normally include checking pressures, making sure there are no obstructions, cleaning/checking filters, checking fitting security etc etc..
AltonD's Avatar
AltonD AltonD is offline
Don't forget the issue with the flop tube coming off inside the tank. I didn't see that he switched tanks.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
