Old 09-30-2011, 09:54 PM
westexflyboy's Avatar
westexflyboy westexflyboy is offline
Originally Posted by Martin Sutter View Post
I chose to mount the XRX in the left wing tip because it contains no antennae or other electrical devices other than the nav and landing lights. I fabricated a pad from structural high density foam and glued it in the wing tip with flox and epoxy as far out board as possible. This location places the unit about 12" from the wing rib.
Martin,
We're gonna try mounting the Zaon in the right wingtip of the RV-10. Since your install is functioning well, would you describe the fore/aft placement? Wondering how far back to stay away from that wingtip landing light. A photo of your foam pad installation would be great!
Chase Snodgrass, CFI, A&P
Big Bend EAA Chapter President
EAA# 529395
RV-10 N104EP Completed and Flying!
Presidio, Texas
www.flybigbend.com
Old 10-01-2011, 08:05 PM
GusBiz's Avatar
GusBiz GusBiz is offline
Default Why no remote mount antenna?
I understand the function of the unit.
It is a get up and take it with you kind of unit.
However what would it have hurt to have put in remote mounted antenna plugs in the back of it.
I guess they never thought of that at the time considering the intended market and now the thing is built and to get a redesign costs money.
I would definitely be more interested in "installing" it if there was a top and bottom antenna mount possibility.
It just doesn't seem that hard of an alteration. Maybe I am wrong...
Gus Bisbal
RV7
Obsession only exists when someone else isn't doing it too.
Old 10-02-2011, 05:51 AM
sailvi767 sailvi767 is offline
I called Zaon and asked that question and if one was perhaps coming out soon. The answer was that they had already attempted it and it could not be produced at a cost they felt would sell and that nothing as planned. This was as of about 6 months ago.
George
Old 10-02-2011, 07:32 AM
Brantel's Avatar
Brantel Brantel is offline
Yep they did it several years ago. Even had working prototypes. They mentioned the price and everyone laughed. Not gonna fly was the overwhelming response.....
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 10-02-2011, 07:32 PM
Mike D's Avatar
Mike D Mike D is offline
It is intresting that this thread has surfaced again. I have been rethinking my response I made back in feb.
I absolutely hate it on my glare shield. And because I have a slider with the steel bar supporting the roll bar, I have noticed a blind spot. There are a few spots of "reflection" also. When the xrx indicates a plane to my 2-o'clock, it is actually at my 10-o'clock. I have gotten used to it and now look there.
The xrx can see planes to my 6, so I am now thinking a wing mount might not be bad. There may be a blind spot, but a plane traveling perpendicular to me will pass behind me.
Anyway, I will try the wing mount and see.
The xrx is not a replacement for a good eye scan. Just a reminder sometimes.
Michael Delpier
RV6A -O-320, fixed pitch, GRT Sport, 496
RV-10 - working on finish kit
Houston
Old 04-21-2012, 08:15 PM
Mike D's Avatar
So, here is the report back.
It will work in your wing tip. I mounted the Zaon as for out in the wingtip as possible and I am happy to say it works as well as on the glare shield. I wanted to wait until I had a good feel for what was capable in the wing tip before I posted.
If you remember, I did have some issues with reflected targets when on the glare shield. I don't have that issue in the wingtip. But I do have a very slight blind spot. But it is not where I expected it to be. It is intermittent and at my 9- o'clock slightly low. This is odd because the Zaon is in the left wingtip. I can read 3-o'clock. But it is a very small blind spot. If I roll either way, the target will show up.
Anyway. Here is my mounting.
Michael Delpier
Houston
Old 04-21-2012, 09:15 PM
tommylewis's Avatar
tommylewis tommylewis is offline
Default moved my XRX
A few weeks before Sun & Fun, I moved my XRX from a mount on the baggage wall to my right wing tip in my RV7a. I mounted it similar to what Martin Sutter did, in a foam cradle as far out as possible in the wing tip. In that wing tip, I have a strobe power supply and a VOR/ILS antenna. It works well. The other detail is in the XRX you select aircraft type and I selected none. I am very pleased with the results.
Tom Lewis
RV7a N967BT 1900 hrs.
RV10 N143EB 960 hrs.
Granbury, Tx
http://bit.ly/2bnimsZ
Old 05-08-2012, 03:02 AM
Finley Atherton Finley Atherton is offline
Inspired by this thread I decided to install the XRX in the wingtip of my 9A. I have not done a lot of flying with it yet but it seems to be working well.
I carved then glassed in a foam block so the XRX sits level all round with the aircraft in the straight and level flight attitude.
The device is attached by sticky back velcro plus a cable tie (possibly not neccessary)
Fin
9A
[IMG][/IMG]
Old 06-05-2012, 08:50 PM
Pepe Pepe is offline
Banned
I found an easier way to deal with the remote antenna issue by installing a Monroy Traffic-Watch+ unit. The Monroy antenna is the same size and shape as a transponder antenna and is installed on the belly. The unit itself can be panel mounted. It works pretty well. It is also FAA approved for certified aircraft. For less than $1K (combo package) is a pretty good deal. Check http://www.monroyaero.com/ATD300Webpage8.pdf
Pepe
Old 06-09-2012, 07:33 PM
dwschaefer's Avatar
dwschaefer dwschaefer is offline
Default XRX in Wing Tip
I mounted mine behind me on the baggage compartment wall a year or so ago with brackets from RAM. Worked super feeding a signal to my GRTs and was high enough in the canopy to be the highest object around. Had the XRX wired to come on automatically with power.
FYI ..Just removed it this week to install ADS-B. If anyone knows anyone interested in an low-mileage XRX and a RAM mount, please sent me a PM.
DWS
