06-06-2012, 09:01 AM
7 attachment is different...
Originally Posted by BillC
Thanks for the info Rob,
Since it's an easy place to look I'll be inspecting this weekend. As a reminder, The same vertical stab is also used on the 7's so it would probable be a good idea to post something over there or in the general section just in case they don't see it here.
The attachment of the vertical stabilizer on the 7 is different (different horizontal stabilizer and spar)
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
06-06-2012, 09:11 AM
Thanks Stephen I will remove that post, or state disregard, because I was mistaken.
06-06-2012, 09:13 AM
Senior Curmudgeon
I deleted it for you.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
06-06-2012, 09:17 AM
VS Attach Plate Crack
Thanks Mike that was fast, I went back and said where did it go?
06-06-2012, 09:41 AM
Since it's a simple part and the elongated holes are for intial assembly only.
I would make my own replacement part from the same thickness material and just have plain round holes for the bolts.
Is there a possiblity that the bolts were not fully torqued?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
06-06-2012, 10:04 AM
slots?
Slots are not preferred at loads points for this very reason. A better design would be line drilled. OK, now the decision for me, make a replacement part or just add a washer? Vans may consider a Service Bulletin for this finding. Did someone copy Vans?
Steve Melton
Cincinnati, OH
www.rvplasticparts.com
06-06-2012, 10:30 AM
Good find and inspection.
That may have been in the older kit (RV7) mine which was built in 2009, the attach point was not pre-drailled and was to be drilled by builder.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
06-06-2012, 10:44 AM
Vertical Stab Attach Plate Crack
yes, I called them yesterday, and sent an email this morning.
06-06-2012, 02:00 PM
Please let us know what they say. My 9 is just about to have its tail feathers mounted.
Kurt W.
RV9A
FLYING!!!
06-06-2012, 05:11 PM
If you make a new part it would be easy to incorporate a rather obvious load path improvement...straighten the left edge:
Is the left edge in the photo rounded and smoothed, or square-edged with an "as delivered" finish?
The most likely cause of overload is ground handling. Folks tend to use the leading edge of the VS as a handle.
Dan Horton
RV-8 SS
Barrett IO-390
