O-360-A4A (peanut drone engine)
Originally Posted by Wesael
Well after running the supercharged 540, the O-360 drone motor received the name of peanut. Because it just look small? The final numbers of the last dyno run before it came off last weekend were. Un-corrected @ 8218 density alt. 2650rpm: Torq. 657ft-lbs // 331.37hp. Installation in process, will be flying to KOSH.
