  #11
Old 05-28-2012, 10:27 PM
springer springer is offline
Originally Posted by N941WR View Post
My smart alec reply was, "Hey, you need to clean the belly of that RJ, it sure is dirty!"
Since I had him in sight and could tell we would pass under him, I did not consider it a safety issue. Besides, at that point, starting to maneuver could have been the thing to cause an accident.
Out of curiousty, what would the rest of you do, if you were in the same situation?
An RA requires an immediate and positive response to the commands given by the TCAS which are either a climb or descend maneuver. If I was in his position without an RA and did not have you in sight, I would have asked for a vector away. With 500' separation, you seeing me is not valid enough for me and the 280 bodies sitting behind me to continue on present course.
If I had been you in my RV-4 I would have maneuvered 20-30 degrees away from the RJ and not made the unprofessional remark.
As an aside, when departing on weekends out of Florida airports, I would brief my first officers to climb with the autopilot on (both heads looking out the window) and at near Vzf to 10,000'.
Old 05-28-2012, 10:48 PM
PCHunt PCHunt is offline
Originally Posted by springer View Post
................If I had been you in my RV-4 I would have maneuvered 20-30 degrees away from the RJ and not made the unprofessional remark.
With a sense of humor like that, I bet you were a barrel of laughs on layovers.
Old 05-28-2012, 11:07 PM
What is Vzf?
Old 05-28-2012, 11:13 PM
ATCs job is to separate IFR aircraft from other IFR aircraft. After all, if you were below 10000' you aren't required to have a mode C, nor are you required to talk to ATC. Exception: in class B ATC will separate all aircraft. that's why VFR minimums go to "clear of clouds".
Old 05-29-2012, 04:45 AM
RV8R999 RV8R999 is offline
and since he wasn't being paid for flying, he isn't a professional pilot by definition, and therefore free to have some fun...
Old 05-29-2012, 04:57 AM
rbibb's Avatar
rbibb rbibb is offline
Interesting thread. I think the best course would have been for the RV-4 driver to simply reply, "Nxxxx, Traffic in sight". Then everyone (RJ crew, ATC) would know that the RV has not only the requirement but the ability to execute the expectation that, as a VFR flight, they would maintain visual separation. There is nothing that creates a more nagging feeling in an aircraft then to be advised of traffic and not be able to see it. Knowing that the other guy sees you alleviates that anxiety.
As for the snarky comment - I have no problem with that as long as some rapport had been established before it was made. Letting the RJ crew know they are seen would probably put them more in the mood to accept the good-natured josh.
We are all ambassadors for our individual segments of aviation and as such our interactions carry a lot of weight in creating, modifying, or reinforcing impressions individuals in other segments have our our respective niches in the aviation universe. I always try to sound as professional on the radio as possible such that the true professionals that hear my radio calls won't be able to tell that I'm a private sport pilot and think I've. And I find it can be done while still managing to interact with ATC and others in a fun way. IN the enroute phase on a non-busy frequency you might say one thing; congested one in busy terminal area the less said the better.
My two cents...
Old 05-29-2012, 05:13 AM
KRviator's Avatar
KRviator KRviator is offline
Originally Posted by apkp777 View Post
I am very surprised you didn't see the RJ do an evasive maneuver based on a "RA" (resolution advisory) on his TCAS. It's likely they actually got a visual on you at some point. They may have secretly been trying to get close look at that new Skyview in your sweet blue and white -9. I know of at least one RJ pilot that has a strange fetish for -9's with skyview.
To get an RA, both aircraft need to be equipped with TCAS, not just Mode C. The regional would only ever have got a TA.
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
Old 05-29-2012, 05:50 AM
tkatc's Avatar
tkatc tkatc is offline
This is incorrect. The RJ could have easily gotten an RA based upon the RV transponder information ONLY. The likely reason there was no RA in this case was because everyone was in level flight and the vertical separation was not diminishing enough to trigger the advisory.
Not sure why the RJ boys seemed so uptight but the "dirty belly" comment probably reminded them to relax. Traffic was called, the RV reported them in sight, and they probably saw the target on the fish finder the entire time.
Track my RV7A!!
Bought my flying -7A
Building an -8! (Fuse)
Old 05-29-2012, 06:02 AM
Sid Lambert Sid Lambert is offline
That's probably what gave them the willies. They both had their heads down watching the finder and not looking out the window.
500 feet crossing north of Atlanta in VFR seems to be the norm.
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
Old 05-29-2012, 06:21 AM
Alan Carroll's Avatar
Alan Carroll Alan Carroll is offline
I think about this every time ATC calls out airline traffic anywhere close to me. Its always easy for me to see him, but harder for him to see me. The other guy also has no real way of knowing whether I'm a skilled professional with eagle vision and decades of experience, or disoriented student pilot. Its actually rather impressive that things seem to work out, due in part to TCAS?
Alan Carroll
RV-8 N12AC
