Old 05-27-2012, 09:57 PM
jlott's Avatar
jlott jlott is offline
Default Is my pneumatic squeezer broken?
Suddenly, my pneumatic squeezer isnt setting rivets straight. Basically, at the end (most extended) part of the squeeze, the set holder is visibly shifting toward the tip and side of the yoke which makes the shop head set lopsided...
I verified I have the set holder inserted into the base correctly. Is my squeezer broken? Could it just be the set holder itself?
Help! Any insight would be greatly appreciated.
(Photos are on my blog: http://www.n251rv.com/2012/05/27/pne...eezer-problem/ )
N251RV (Reserved)
RV-7A
Empennage (In Progress)
www.n251rv.com
Old 05-27-2012, 10:04 PM
Stalldog Stalldog is offline
You're using a no hole yoke, which I assume is pushing the set to the upper limits of travel. Some of the vendors say you need a longer 1.25" set for this to work, depending on what you have for the squeezer. If you install a holed yoke that holds the other end of the set, thus reducing the travel, do you still have this problem? I bet the problems goes away, check and see.
Jim
Lenexa, KS
RV-7A
Old 05-28-2012, 04:14 AM
FlyingArcher's Avatar
FlyingArcher FlyingArcher is offline
You might just be at the thread limit of your adjustable holder. While it's still guided at the bottom, it stays straight, but when reaching full extension, the guided part is almost none, and it's able to move sideways.
As Jim said, you might need a longer set if you want to set short rivets with this no-hole yoke.
Daniel Mouly
VAF #778 - [2013 payment done]
RV-9A Emp. & Wings 95%, Fuse 70%
Austin Healey 3000 MKIII fully restored
LFCD (Andernos Les Bains), France
Construction Log comments in French (not really up to date, sorry)
Old 05-28-2012, 06:53 AM
rocketbob's Avatar
The no-hole yokes have a taller base. Because of this the adjustable shaft won't work well with a thin flush set since its near the end of the screw travel and there's not enough of the shaft in the bore of the yoke to adequately support it. You would get better results with a longer flush rivet set.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 05-28-2012, 08:16 AM
CPSONE's Avatar
CPSONE CPSONE is offline
Default Bent?
Make sure your adjustable set holder is not bent.
Mike
RV-6 emp, done-sold,
RV7A QB. Passed pre-cover and sold!
Disclaimer: Everything I say can be presumed to be wrong. Don't try this at home.
Old 05-29-2012, 07:53 AM
jlott's Avatar
Thanks for the feedback and ideas guys
The adjustable set holder appears to be straight, according to my machinists rule.
I tried using a "holed" yoke with the longest flush set that I have. That caused the adjustable set to only have about 1/4" of threads exposed since it was screwed down so far. The problem was somewhat lessened in that case but isn't completely gone. Shop heads are still set visibly lopsided.
I'm running out of ideas. Perhaps this squeezer is damaged internally... There is plenty of grease in there so its not getting bound or anything.
I'm going to give it a bit more thought but I think I'm at the point of needing to contact Isham.
N251RV (Reserved)
RV-7A
www.n251rv.com
Old 05-29-2012, 08:25 AM
Yep, I'd contact Isham. When I called them last week I had to leave a voicemail for them to call me back, but they did just that later that day.
Jim
Lenexa, KS
RV-7A
Old 05-29-2012, 08:17 PM
Forgot to mention to let us know what Isham says. Inquiring minds would like to know.
Jim
Lenexa, KS
RV-7A
Old 05-29-2012, 08:58 PM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
The no hole set that I purchased from Isham came with a separate and longer shaft, along with an additional longer set. Do you have the longer set? From time to time I use the adjustable shaft for when the material is thicker and does not require the shaft be screwed out to the end
Bill Peyton
RV-10 - 1125 hrs
N37CP
First Flight Oct 2012
Aviation Partners, LLC
Old 05-29-2012, 09:06 PM
You know, it's strange, but when I spoke with Isham a couple of weeks ago when looking for a no hole yoke they also indicated I would need the longer adjustable set. I ended up buying a no hole yoke from Cleveland, and they indicated I would not need a longer adjustable set, that it would work with my existing set. I've installed and used it with my existing set and it seems to work fine. So, I'm guessing the one from Isham is maybe a little different from others and that it does require a 1.25 inch set. Again, let us know what Isham says about your problem and how to resolve it.
Jim
Lenexa, KS
RV-7A
