Call Van's and get their directions
Charles,
Dan's info is GREAT.
My memory of the Van's intersection fairings is they are intended to have AT LEAST one layer of glass added to the outside surface. Add a single layer with peel ply to get a smooth surface. The intersection fairings may also need a moderate amount of trimming. I believe Van's has a single page sheet that describes how they expected the intersection fairings to be finished / installed. I'd recommend getting the directions from Vans in addition to reading and applying information from Dan.
Regards,
Roy
N174RT (RV-7A) first flight 5/31/11, 1780hrs as of August 2020:
Tip-up, Lycon IO-360 EXP, WW 74HRT, AFS 5600T, AF-Pilot, IFD440, SL-30, echoUAT, D100 for backup, CQ1 headsets, CMW E-Lift
Our other riveted aluminum monocoque RV is a 25' Airstream
Past aluminum monocoque vehicles:
N601RT (CH601HDS) First flight 5/03, 1550hrs after flying 8 years: 912ULS, GNS430W, SL-30, D10A Sold
1995 Midnight Pearl NSX w/BBSC Sold
EAA Chapter 105 board member 2010->2015
