Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Glass Cockpit
Old 05-02-2012, 03:59 PM
SteinAir SteinAir is offline
Default G-Meter
Saw this a little while ago and snapped a fuzzy pic (perhaps the Garmin guys will post a nicer crisp pic) with my cell phone, but pretty nice display of a G-Meter and some nifty functionality along with it.
Stein
Old 05-02-2012, 04:29 PM
Bill Dicus Bill Dicus is offline
Default G METER
Pic's fine and the G meter looks great. Is -3 the real negative limit?
Bill Dicus
Shorewood (Milwaukee) Wisconsin
RV-8 N9669D Flying 12/4/14!
Flying Pitts S-2A, Piper Lance
Old 05-02-2012, 05:03 PM
Ironflight's Avatar
VAF Moderator / Line Boy
We flew with a little bit in Beta just before Junior went in to the paint shop - works nice, and no, I didn't bother to check how far the negative side went....that's just painfull!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 05-14-2012, 09:49 PM
Flybipe Flybipe is offline
Default Roll rate limitation
Does anyone know what the roll rate limitation is for the G3X AHRS unit? I'd like to put this in my Pitts because it is a nice light stand alone package for a plane like that but don't want it to become a distraction if it is always "tumbling".
Can you display the g meter and, say, the engine data over a black screen during acro?
Old 05-15-2012, 10:27 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Flybipe,
As stated in the G3X installation manual, "The GSU 73 AHRS is capable of maneuvers through a range of 360? in bank and pitch. The rotation rate
capability is ?200? per second."
There is no way to manually turn off the attitude presentation on the PFD, but should you perform acro maneuvers long enough to exceed the limits of the attitude algorithms, it will replace the attitude presentation with a black background with instructions to keep the wings level while the in-flight alignment occurs.
The airspeed, altitude, vertical speed, engine data, etc will still be presented over the black background.
A picture of this presentation is on page 10-6 of the G3X installation manual if you are interested.
The G3X attitude presentation can never actually "tumble" (provide incorrect attitude information). Proprietary monitors are used to detect an out-of-limits condition and invalidate/remove the attitude presentation before it can become incorrect.
Steve
Garmin G3X Support
g3xpert@garmin.com
Old 05-15-2012, 10:51 AM
Ironflight's Avatar
Based on our Phase 1 experience with our G3X-equipped RV-3, I can confirm that it works exactly like this - I was only able to make this happen once, with a pretty radical roll/pitch/yaw sequence. After reporting it to the Garmin guys, they did some software tweaks and as hard as I tried, I wasn't able to make it happen again - so it's pretty robust.
Paul F. Dye
Old 05-16-2012, 09:20 PM
Default Thanks....
This is all helpful. I now see that Greg Poe had one in his new MXS so it must have worked ok for him....
Old 05-16-2012, 09:24 PM
java's Avatar
java java is offline
Default Silly question...
As I work on my G3X panel upgrade, I still don't know how software updates are made. Is it easy? What's the process?
Nice kit that I've seen so far BTW. Love the idea of the config modules that sit in the D-sub backshells that keep settings even if you switch out screens.
JV
Calgary, Alberta, Canada
RV7 QB - Airframe largely complete, sans canopy and glass... unfortunately sold
RV6 - O-360-A1A, Hartzell CS, dual G3X VFR... purchased
Dues paid 2015
"Being defeated is only a temporary condition; giving up is what makes it permanent."
-- Marilyn vos Savant
Old 05-17-2012, 06:03 AM
Ironflight's Avatar
Piece of cake - software comes from the 'net to your computer, you run it and it writes the code to a memory card, you put the card in the front of the GDU, and it asks if you want to install it. Say yes, and watch it go.
Paul F. Dye
