Go Back   VAF Forums > The Never Ending Debate Section > Tools
Old 05-07-2012, 12:37 PM
NovaBandit's Avatar
NovaBandit NovaBandit is offline
Default Cleaveland Lightweight Air Hose Review
I finally threw together a quick video review of the Cleaveland lightweight air hose kit I've been using for the past few weeks.
http://www.edandcolleen.com/cleavela...se-kit-review/
Long story short... air hoses are one of the MANY things that I never gave a second thought to before building. But once you use a quality piece of equipment that makes building easier, you can never go back! This is definitely one of those situations. The coiled yellow plastic air hoses shan't be used again.
Ed Kranz
RV-10 N829EC - Flying
First Flight: 8/29/15
KSGS - Fleming Field, South Saint Paul, Minnesota
YouTube.com/GoodPlaneLiving
-- Build Timelapse and Travel Videos . . GoodPlaneLiving.com -- Build and Travel Blog
Old 05-07-2012, 05:15 PM
Flyin'Bryan's Avatar
Flyin'Bryan Flyin'Bryan is offline
Default I use it too
Ed, I have used my extensively since day one as well, but up until about a week or so ago I have to admit I wasn't exactly sure why, other than for the smaller connectors that go with it. I was placing an order for several more of the short NPT connectors that are needed in order to use that hose (I now have more tools and need more connectors), and I stumbled upon Mike's how-to video regarding the hose and the connectors.
He makes two important points in the video that further affirmed that this was a smart choice:
1. The smaller hose is about 1-2 pounds lighter at the tool and is easier to maneuver than a standard hose. I think it may even be more flexible and easier to use than the smaller plastic hoses since it is a straight hose, while I believe the plastic ones are mostly coiled. Helps minimize the fatigue factor during long sessions.
2. The quick connectors attached to the hose can simply be pushed onto the other connector attached to the tool by pushing on the base of the connector. You do not have to pull back on the quick disconnect on the end of the hose to attach it.
I think the hose they provide is great, as well as everything else I have ever purchased and used from Cleaveland Tools.
Bryan Raley
http://bryansrv8project.blogspot.com/
Building RV8
EAA Chapter 301
CFII/MEI, ATP
SportAir Workshop Graduate x 4: Sheet Metal, RV Building, Electrical, and Composite classes.
Tail Wheel Endorsement Completed
Empennage done, Wings in progress, N462AK reserved.
Old 05-07-2012, 07:05 PM
Caummisar's Avatar
Caummisar Caummisar is offline
Default Mini coupler caution
I agree these light weight hoses are nice to have. I've used Avery's version for several years. One caution I'd like to pass along deals with the brass female mini coupler. If you look at the tip of the coupler where the male fitting is inserted, you will see a snap ring. The snap ring, made from wire, fits into a groove in the mini coupler. The snap ring, because of its location on the tip of the coupler, is susceptible to damage. If you drop the hose when a tool is not attached and the mini coupler hits the concrete, eventually the wear and impact will dislodge the snap ring and the mini coupler will eject three or four ball bearings that are needed to keep the male fitting in the coupler. Just like any small parts, the ball bearings will roll to those impossible to find locations under something immovable, never to be found. The snap ring will magically disappear and you will have to order another $7 to $9 mini coupler.
Soooooo, be gentle with these light hose and the female mini coupler when there is no tool attached.
VAF# 835
RV-7A- Instrument Panel/FWF/Engine Mounted
Slow build --- ALL THE WAY
Victim of SB-632-B
2020 Dues Paid
Old 05-08-2012, 09:57 AM
Scbado Scbado is offline
I also use the Cleveland mini hose. I am very happy with them and the quality. Although sometimes I wish they were a little longer.
A way they could be made better is if someone could devise a way to get rid of the air hose and make the tool blue tooth compatible Yes I know there are battery powered tools but they are big & heavy ciompared to an air tool.
Jerry Roeder
C150 N222PA at 02C
RV-9A Standard Build Slider
Empennage done
Left Wing built
Right Wing built
Fuselage in process
Finish kit received
Moved Project to 57C
Old 05-08-2012, 03:18 PM
clevtool's Avatar
clevtool clevtool is offline
Thanks for the reviews and comments! On the coupler getting beat up, that is true, since it is brass it could be damaged by an impact. We have been using them in our shop for 15+ years and usually wear out the hose first. I do usually drop the coupler so that it hits my foot when I drop the hose on the floor.
We have the kits that Ed mentions:
http://www.cleavelandtoolstore.com/p...p?number=ACKIT
Or we have a 'deluxe airhose kit' so you can leave three hoses connected to a manifold. Leaving one connected to a blow gun, one to a drill, and one to a squeezer is really handy. They use the same mini connectors.
http://www.cleavelandtoolstore.com/p...umber=ACdlxKIT
Let us know if you ever have other trick products that you would like us to carry!
Mike Lauritsen
Cleaveland Aircraft Tool
800-368-1822
www.CleavelandTool.com
mike.toolman (at) gmail.com
Like on Facebook - Follow on Twitter - See on YouTube
Old 05-08-2012, 03:40 PM
schristo@mac.com's Avatar
schristo@mac.com schristo@mac.com is offline
Default Love mine... never gentle ;)
I have used mine from day one of construction and converted all tools immediately. I use and abuse mine and have never had an issue. One of the great tool buys that you find that just works so much better than other solutions but does not get much notice.
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
Old 05-08-2012, 04:55 PM
GLPalinkas's Avatar
Default Love mine
I wouldn't do it any other way. I bought mine from Mike (Cleaveland Tool) about 12 years ago. It is the way to go, especially in tight spaces.
Venice, Fl
Old 05-08-2012, 05:25 PM
rv7boy's Avatar
rv7boy rv7boy is offline
Forum Peruser
I used the yellow "slinky" type hose for the first few months and wondered if there were a better way. I ordered one hose with fittings from Cleaveland, and after a few weeks ordered another one.
I'm very happy with these and like everything else I've bought from Cleaveland, these hoses and fittings are high quality.
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
Old 05-08-2012, 06:14 PM
dmaib's Avatar
dmaib dmaib is online now
I ordered, and we used, the Deluxe Air Hose Kit (with the manifold) from Cleaveland when we started the project in 2006. Wally Anderson at SynergyAir sat down with us after we finished his class and went through the Cleaveland and Avery catalogs and made recommendations about what tools we would appreciate having. The lightweight hoses and manifold were one of the best recommendations. Still have them and still use them.
David Maib
RV-10 N380DM
New Smyrna Beach, FL
VAF Paid 1/21/2020
"In '69 I was 21, and I called the road my own"
Jackson Browne
Old 05-08-2012, 08:36 PM
NovaBandit's Avatar
I probably would have went with the deluxe version with the manifold as well, but I had already made a DIY manifold with a regulator right on it... So I could run two different pressures simultaneously.
Ed Kranz
