Old 05-06-2012, 02:31 PM
Bevan Bevan is offline
Default magneto hold-down bolt torque?
I had to remove a mag to get at a oil hose fitting. Does anyone have a quick reference for the torque spec for the bolts that hold down the magneto? Looks like 5/16 course thread so I'm thinking 160 in lb max but this seems much less tight than they were.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 05-06-2012, 02:50 PM
TSwezey TSwezey is offline
Bevan
Maybe the last person didn't torque them correctly.
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
Old 05-06-2012, 02:57 PM
[quote=Bevan;656516]I had to remove a mag to get at a oil hose fitting. Does anyone have a quick reference for the torque spec for the bolts that hold down the magneto? Looks like 5/16 course thread so I'm thinking 160 in lb max but this seems much less tight than they were.
Bevan[/QUOT
What kind of mag? I looked at this this morning. Bendix was listed as 170-320. Slick was listed at something like 130.
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 05-06-2012, 03:49 PM
DanBaier's Avatar
DanBaier DanBaier is offline
Default Your instincts were right - 170 not enough
204 inch pounds (per Lycoming Table of Limits - page 1-37) - be sure to use a new star washer
Dan
RV7A (N7101) - Flying 10/2008
CFI- SE/ME/Inst
A&P
KC2ZEL
Old 05-06-2012, 03:50 PM
They are actually P-mags on a Lyc 0-360. The hold down bolts are actually studs embeded in the case. All we are doing is putting nuts on the studs and torquing. I don't know what the original mag type was.
My torque chart for 5/16 coarse bolt is 160 in lb for max. But surely there is a lyc spec for this torque and perhaps it is different. Anyone have a lyc overhaul manual handy and could look it up?
Bevan
Dual P-mags
Grand Rapids EFIS
Old 05-06-2012, 04:07 PM
Thanks Dan.
Bevan
Dual P-mags
Grand Rapids EFIS
Old 05-06-2012, 05:28 PM
az_gila's Avatar
az_gila az_gila is offline
Thumbs up
This might help for those generic torques for the coarse thread screws on your Lycoming -
NOTE - unlike airframe torques which are quoted dry, these are for lubricated nuts.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
