Old 05-01-2012, 05:06 AM
Future RV 9 Flyer Future RV 9 Flyer is offline
Default Preventing elevator skin cracks
Hi all,I have heard of builders placing a small amount of fuel tank sealant in the elevators to prevent skin cracking. Where should it be placed,between the stiffeners?Thanks
Old 05-01-2012, 06:13 AM
Walt's Avatar
Walt Walt is offline
Just a dab applied at the very trailing edge of the stiffeners, bonding the stiffeners to each other.
Its important that the stiffeners do no contact each other or they will create a stress "bulge" in the trailing edge skin. I'm replacing an RV4 elevator skin right now due to stress cracks from improperly trimmed stiffeners.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 05-01-2012, 06:49 AM
Av8torTom's Avatar
Default As Walt says...
Where Walt said, however I believe this is more of a problem with the ailerons (and other control surfaces) that are folded at the trailing edge. The trailing edges on all the 9 control surfaces are seamed.
N677AT reserved
Superior XP O-320, 160HP
Old 05-01-2012, 07:14 AM
Geico266's Avatar
Geico266 Geico266 is offline
Walt, I know you are a busy guy, but would you post a picture or two?
Thanks man!
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 05-01-2012, 07:30 AM
Walt's Avatar
Thanks man!
I'll try to snap a few before I close up the current repair job, it will be a day or 2 before I get to that point.
Old 05-01-2012, 07:44 AM
aarvig's Avatar
aarvig aarvig is offline
I spoke to Vans on this very subject. The answer I received (from Ken Scott) was that the sealant WAS NOT NECESSARY in aircraft with a a "AEX wedge" (such as the RV-9A) at the trailing edge. Only aircraft with solid or folded trailing edges was this necessary. It is also in the builders manual stating this very fact. Don't add unnecessary weight at the trailing edge of control surfaces. If you don't believe me, call Vans.
Aaron Arvig
RV-9A
Empennage Done
Wings-In Progress
N568AK Reserved
SOLD?but I'll be back
