Old 06-25-2006, 06:06 PM
mlw450802's Avatar
mlw450802 mlw450802 is offline
Default Hylomar vs EZTurn or Fuel Lube
Can anyone offer an experienced opinion of the equivalency of Hylomar Blue sealant and EZTurn?
-mike
Michael L Wilson
Resuming building after a 4ish year hiatus! (life got in the way)
N194MW (reserved) RV9A SB
VAF# 148
Payson, AZ
Old 08-10-2006, 09:31 AM
abuura abuura is offline
I am told Hylomar HPF is no longer available. I call Mattituck and they said they use EZ-Turn (fuellube) for sealing gaskets. The back of the tube indeed says it can be used for sealing gaskets. B&C sticks to their HPF story, but I wouldn't expect them to be experts in the field of gasket sealants.
David Abrahamson
Reston, VA
RV7, N98DA, TMX-O360, CS, slider
Old 08-10-2006, 09:44 AM
Jconard's Avatar
Jconard Jconard is offline
There is also a product called tite seal, which is also specifically designed for aircraft gasket sealing. It is safe and will not harden, so if a chunk gets in the oil, it will not create a clog.
JC
Old 08-10-2006, 10:09 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Originally Posted by abuura
I am told Hylomar HPF is no longer available............
Having recently purchased some Hylomar for an engine overhaul, I can assure you that Aero in Granite City Il. has both the medium and heavy varieties of Hylomar in stock as we speak. Cannot comment on its virtues as a substitue for EZ Turn though. I'd give em a call and see what their professional opinion is.
http://www.aeroinstock.com/Engine_Pa...nformation.php
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 08-10-2006, 05:06 PM
dan's Avatar
dan dan is offline
Haven't used "Hylomar Blue," but if you're using it on fuel fittings or fuel cap gaskets or the like, and it's indeed blue, that might not be the best choice. If I saw blue streaks and didn't know if it was sealant or actually fuel, that could be a pain.
I like that EZ Turn is colorless. In the event I have a leak, I'll see it easily!
Dan Checkoway RV-7
Old 08-10-2006, 05:10 PM
Default Gasked sealants -- no more Hylomar HPF
Preparing to install my SD20 I reviewed B&C's installation instructions. B&C says to use Permatex Hylomar HPF or Loctite; couldn't find either and confirmed with B&C they have no alternate recommendations. The Permatex company website doesn't show Hylomar being available, so I called Mattituck -- who I assume knows something about sealing gaskets -- and was told they use EZ-Turn (Fuelube). Sure enough, it says on the back of the tube that it is suited to gasket sealing. Also was told they use a rubber roller to put a thin coating on gaskets. In a later conversation with a Permatex engineer, confirmed that Hylomar HPF is no longer available and was told that Permatex 97 High Tack is an acceptable substitute. So, armed with my trusty tube of EZ-Turn and a roll of scotch tape and spindle from a dispenser to spread it on the gasket (instead of an $11 roller), installed the SD20. By the way, the SD20's inboard lower nut is hard to reach with the engine off the mounts and even with a crowfoot wrench I had to SWAG the torque; reaching and torquing this fitting properly when the engine is hung looks to be a time-consuming and frustrating endeavor.
David Abrahamson
Reston, VA
Old 08-10-2006, 06:41 PM
mlw450802's Avatar
I don't think Permatex had anything to do with Hylomar.
http://www.hylomar-usa.com/?siconten...ckingid=672078
Do a google search on hylomar and there are lots of hits and many active online sources.
I just recently purchased a tube of hylomar blue within the last month or so.
-mike
Michael L Wilson
VAF# 148
Payson, AZ
Old 08-10-2006, 06:58 PM
mlw450802's Avatar
It is indeed blue and you have an excellent point.
I have discovered though that it is the best air fitting and piping sealant I have ever used!
Michael L Wilson
VAF# 148
Payson, AZ
Old 08-08-2007, 11:47 AM
Lloyd Lloyd is offline
Hylomar can be found at Fowlers Engines in Col, OH
Old 08-08-2007, 12:02 PM
cnpeters cnpeters is offline
Can EZ-Turn be found in your usual HD/Lowes stores, or do folks order it from ACS, etc?? Has anyone had mush use for Permatex Red Silicone RTV? Label says for high temp application.
Carl Peters
St. Louis, MO
RV-9A finishing kit
http://www.mykitlog.com/cnpeters
