  #11
Old 04-22-2012, 03:30 AM
rgmwa rgmwa is offline
Default Mead and Hal-San...
Originally Posted by Hal-san View Post
only in my dreams!
Guys, Tony is right. The pdf file I have is for the Skyview installation with the finish kit wiring shipped prior to 8/25/11 (which is my situation). However, I can easily get the other two files converted at work this week.
Let me know which one you want. The pdf file is quite small, only about 710k. I'll need your email address to send the file as an attachment, so send me a PM.
rgmwa
RV-12LR 912ULS
120346
Old 04-22-2012, 04:54 AM
LittleJoeA LittleJoeA is offline
Default PDF's
I had PDF files made of each module so they could be easily printed for my use.
I thought it would be a good idea to make it available to anyone that wanted to be able to make hard copies.
The first line of my posting makes it clear that they are only for the "Finish Kit Shipped After 8-25-11"
I?m sorry if I offended anyone by making this offer.
Joe Arluck
Livermore, CA
RV-12, S/N 120419
Empennage/Tailcone finished
Wings finished
Most of Finishing Kit finished
"It's sitting on the Landing Gear"
Engine mostly installed
Avionics Kit in Hand
Currently fitting wings
Paid 2018
Old 04-22-2012, 06:57 AM
Walt's Avatar
Walt Walt is offline
I"d like to have a copy, and thanks for taking the time to do this
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 05-02-2012, 09:53 AM
RV12Roger RV12Roger is offline
Default ACAD Dwg of SkyView with finish kits prior to 8/25. - PDF's, Errors?
Does anyone have PDF's in 11 x 17 format, 3 x 17 wide and 3 x 11 high? I could send you a PM. Would DropBox be better than email attachment?
I have a 11 x 17 printer and with a total of 9 pages and at that size should be legible.
Has anyone found any errors in the ACAD drawing.
Old 05-02-2012, 07:01 PM
meadeduck meadeduck is offline
Default D180 drawings
Thanks, tony, and yes, I'd like the ones for prior to 8/25/11 for the D-180.
Old 05-03-2012, 05:24 AM
Meade,
Emailed you the D180 PDF file on 24 April. PM me if you didn't receive it.
rgmwa
RV-12LR 912ULS
120346
Old 05-03-2012, 05:41 AM
Peterk Peterk is offline
Robert,
Would love to have a copy of the D180 file when you get a chance. Send to peterk48@msn.com.
thx.
Pete
Old 05-03-2012, 08:28 PM
bgl's Avatar
bgl bgl is offline
If you would email me also I had the finish kit prior to 8/25/11 my emailis
baynelinden@iw.net
Thanks Bayne
Bayne
Old 05-03-2012, 09:14 PM
MartySantic's Avatar
MartySantic MartySantic is offline
I have tried to convert the file to .pdf using several means WITH no success. Just cannot get the resolution. Best bet is to use the free DraftSight program or AutoCAD.
Marty Santic ----- W9EAA
RV-12 N128MS ----- Now Flying
My RV-12 Build Log - http://www.martysrv12.blogspot.com/
Davenport, IA
Old 05-04-2012, 04:37 PM
Default PDF files
If anybody else wants a pdf of the D180 or Skyview files, either post or send me a PM with your email address and let me know which one you want.
I have printed a Skyview file at A0 size (47"x33") and it's readable, but you may want a magnifying glass to help with the small print. I think anything much smaller than A0 would be too small.
rgmwa
RV-12LR 912ULS
120346
