Go Back   VAF Forums > Model Specific > RV-9/9A
  #11
Old 04-18-2012, 10:22 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
Just for reference, a single strip of Vans copper (1/16 x 1/2) is approx. equal to a #4 gauge wire.
IIRC the firewall layout plans call for two parallel strips in between the two contactors to equal a #1 size cable.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Last edited by az_gila : 04-18-2012 at 05:00 PM. Reason: correction - 1/16 was incorrectly typed as 1/6
Old 04-18-2012, 11:13 AM
gasman gasman is offline
A 2 inch copper coupling is 1/16 inch thick. Just cut and roll out flat. You will have more than enough flat copper to do the job.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 04-18-2012, 12:32 PM
rivetshaver rivetshaver is offline
This is what I bought from spruce.
http://www.aircraftspruce.com/catalo...ges/busbar.php
Gregory Targonski
Peachtree City GA
RV-9A Flying as of September 12, 2013
Old 04-18-2012, 01:39 PM
Wayne Gillispie Wayne Gillispie is offline
Originally Posted by az_gila View Post
Just for reference, a single strip of Vans copper (1/6 x 1/2) is approx. equal to a #4 gauge wire.
Exactly the reason I did not use Vans. Mine is .125" X 3/4" and silver flashed. Yes, it may be overkill. I braze and solder copper tubing for hvac all the time and there is a big quality/strength difference between true buss bar material and your hardware store copper fittings and tubing. Let your buss bars corrode or break and you will be stuck somewhere. They conduct 200-300 A during a normal start.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 04-19-2012, 08:24 AM
PeteP's Avatar
PeteP PeteP is offline
Default My answer
I took a piece of 1/2" copper pipe and squeezed it flat it in the vise. I have access to some pretty neat electrical test gear so this morning I ran an ampacity test on it and it sustained 600 amps at 12volts for over 5 minutes with no problem. I am using the newer inline style Skytech starter that is published to pull around 200 amps max but I suspect that the inrush current is quite a bit higher for a few miliseconds. At either rate I think the $1.85 copper pipe is going to be my answer to the problem.
BTW.. I have a piece of the .0625 by 1/2: strip and I am going to run a ampacity test on it later but I think that a single piece of it has a good chance of being marginal at the high inrush current loads of some starters.
Pete
91072
Old 04-19-2012, 05:06 PM
Jeff R's Avatar
Jeff R Jeff R is offline
I doubled up on the copper strip Van's sells.
Jeff Rosson
Repeat Offender
RV14 - Working on Empennage/Tail Cone
RV9A - Completed! First flight on July 18, 2012!
Based at Merritt Island, FL (KCOI)
VAF Number: 1170
Star Trek Quote: "Logically, it could work. Also, logically, there are a hundred variables, any one of which could put us in a worse position than we're in now." Mr. Spock in Return to Tomorrow
Old 04-19-2012, 07:02 PM
az_gila's Avatar
That's good since the plans say "2 Reqd." right by the picture of the bus bar...
As I mentioned earlier it makes it equivalent to about a #1 cable.
Gil Alexander
