Old 04-16-2012, 07:32 AM
rwwende rwwende is offline
Default Front Seat belt bolts and canopy
Do you glass over them?
thanks
Ross
Old 04-16-2012, 07:56 AM
Wayne Gillispie Wayne Gillispie is offline
I did not glass over, same as door screw heads. I did not build a velocity xl. Painted over most rivets and all screws without worrying with cosmetics. Saves time now and later, money and weight.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 04-16-2012, 12:50 PM
9GT's Avatar
9GT 9GT is offline
I filled mine with flox and put a couple layers of BID down and fared it in with micro. Note that before I did that, I ground a couple of flats on the heads to prevent spinning and embedded and filled them with flox before covering.
David C.
Howell, MI
Old 04-17-2012, 08:39 PM
MauleDriver's Avatar
MauleDriver MauleDriver is offline
Default I glassed them
...but I ground a groove in the glass aligned with the screw slot and stuck a pull rivet shaft in the screw slot to keep it from turning.
Old 04-18-2012, 08:30 AM
johngoodman's Avatar
johngoodman johngoodman is offline
Glassed it over.
John Goodman - 40572
First flight was 25 June, 2011
N711JG
Old 04-18-2012, 10:07 AM
Phil's Avatar
Phil Phil is offline
Ditto.....
Old 04-18-2012, 11:28 AM
Space Cadet's Avatar
Space Cadet Space Cadet is offline
Default Nope
Glad I didn't glass them over, pulled them off this week to return a stuck retraction mechanism to Hooker.
Dwight
RV-10 #40762 - 100 hrs+
Denver, CO
Old 04-18-2012, 02:41 PM
paul330 paul330 is offline
I'm doing my canopy/doors at the moment and must admit to being in a bit of a quandry. Glassing over the seat belt fitting/front strut/door brackets seems great from the aesthetic point of view. However, I'm a bit worried about future access for servicing or replacement.
Having said that, I guess the only thing that might conceivably need replacing would be the door hinge bolt due to wear - but that is the ugliest bit!
Paul
Mercy Air, White River FAWV
RV-10 ZU-IIZ - "Zeus"
2019 Donation Made
Old 04-18-2012, 08:01 PM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
Paul, I have seen several -10s with nothing but paint on the door hinges. They really don't look bad at all. I fabricated some covers out of .032 and threaded two holes in the hinge half for a 4/40 CS screw to hold them on. It still leaves easy removal.
As for the Seat belt attach point. I would not glass over it. Someday it might have to be removed and it would then be a major hassle.
I am regretting having fiber-glassed my HS and VS tips for that exact reason. If one gets damaged, then I am painting the whole surface.
Now on the other hand, if you are building a show plane, go for it!
Bill Peyton
RV-10 - 1125 hrs
N37CP
First Flight Oct 2012
Aviation Partners, LLC
Old 04-19-2012, 09:48 AM
CharlieWaffles's Avatar
CharlieWaffles CharlieWaffles is offline
I got my door hinges nickel plated and that removed the desire to fabric a cover plate and all the hassle of doing that. Now the screws are accessible for removal. That being said, all of the other canopy bolts/screws are being glassed in. IF there is ever a serious enough need to replace one, you can also use a tool like a rivet shaver or something and dig out your screw head.
CharlieWaffles - But you can call me "Mark"
RV-10
N928MT
Flying - AKA Still Tinkering
Build Project Site
