Go Back   VAF Forums > Model Specific > RV-9/9A
Old 04-17-2012, 09:23 PM
PeteP's Avatar
PeteP PeteP is offline
Default What size and where to find buss bar
What kind of (size) copper buss did you use between the master and starter relays. I cant seem to find any info on the proper size. Vans sells a copper buss for about $23 but no discussion on size and use.
Pete
9A 1072
Old 04-17-2012, 09:51 PM
bruceh's Avatar
bruceh bruceh is online now
Recheck your price! I used the one that Van's sells for $3.85. Just a strip of copper 12" long by .5" and .063" thick.
Bruce Hill
2020 VAF donator
Old 04-17-2012, 10:03 PM
Greg Arehart's Avatar
I just found a piece of old scrap copper in my junk pile and cut it to the appropriate size, drilled a couple holes and....done.
Greg
Greg Arehart
N 7965A
Old 04-17-2012, 10:24 PM
frazitl's Avatar
frazitl frazitl is offline
Default Take a look
at large diameter copper fittings at Lowes or Home Depot. I cut mine from copper fittings found in their aviation departments... Just cut and flatten to your needs.
Terry F.
RV 7A N457RV
250 hours and lovin it!
Southern Nevada EAA Chapter 1300 - www.eaa1300.org
Paid VAF 03/17
Old 04-17-2012, 10:25 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Yep...........
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 04-18-2012, 05:51 AM
Wayne Gillispie Wayne Gillispie is offline
Storm Copper in TN.
http://store.electrical-insulators-a...-unplated.html
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 04-18-2012, 06:24 AM
OregonRVguy's Avatar
OregonRVguy OregonRVguy is offline
Smile Van's part #
Van's part # is "ES BUSS BAR-063X.5X12" and also give you dimensions....AND it is priced at $3.85
Old 04-18-2012, 07:55 AM
Paul K Paul K is offline
1/2 inch copper pipe flattened in the vice. I made it longer than needed so I could add a mounting hole to the bottom. VP-x attached here.
Paul K
West Michigan
2020 donation made, exempt but worth every dime!
Old 04-18-2012, 09:32 AM
jdeas's Avatar
jdeas jdeas is online now
Default Local metal supply store
Check with your local sheet metal dealer. Most have short ends (scrap) sold by the pound that would do the trick.
JD
RV-7 N314SY (KWHP)
IO-360-B1B
CANbus based trim/flaps and electrical
Old 04-18-2012, 09:37 AM
Neal@F14's Avatar
Neal@F14 Neal@F14 is offline
I've used a short length (~6") of battery cable (#2 tefzel) bent into a tight U-shaped jumper with terminals on it, to connect the master relay to the starter relay, and mount both relays side-by-side each other with correct spacing for the U-shaped jumper to fit well.
Neal Howard
Airplaneless once again...
