04-03-2012, 01:45 PM
PMags and G3X
I'm wiring my engine monitoring system and was wondering what people are using for their tach output.
Will the G3x read the tach output off the Pmags? One or both?
Kai
04-03-2012, 02:21 PM
Hello Kai,
Yes, the G3X system is compatible with the tach output from various electronic ignitions systems, including the P-Mag. Since the P-Mag tach signal is available regardless of whether or not its P-lead input is grounded, you really only need to connect the tach output from one P-Mag.
For dual electronic ignition system installations using ignitions other than the P-Mag, you canconnect the tach outputs from both ignitions as shown in Figure H-1.2 of the G3X Install Manual and the system will use whichever RPM signal is the higher of the two.
thanks,
- Matt
Garmin G3X Support
g3xpert@garmin.com
04-03-2012, 04:53 PM
VAF Moderator / Line Boy
As Matt said - it works great! I connected both before I realized that the P-Mags worked as Matt explained - just more redundancy I guess.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
04-03-2012, 06:46 PM
Thanks guys.
Paul,
Did you use the ammeter shunts supplied with the kit or go will Hall effect sensors?
Kai
04-03-2012, 07:12 PM
Thanks guys.
Paul,
Kai
I used the shunt - works great!
Paul F. Dye
04-03-2012, 07:16 PM
If the G3X has two electronic tach inputs, wire them both up.
In my preflight, I not only ground the P-mags but drop power to them as well. In this case, it stops reporting the RPM; however, because I have both of them wired up and I only power one down at a time, I still get a tach reading. This setup is with a Dynon, not a Garmin.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
04-27-2012, 12:49 AM
EI options
Has anyone used an electronic ignition set up that consisted of a LightSpeed III with a P-Mag. Are they compatible?
Grim
04-27-2012, 03:01 PM
Grim
Yes...but in that case the easiest solution is to just hook up the Pmag and be done with it...
Stein
