johny
knots, mph whatever at 17000' still have a Vne problem in my opinion. Regardless maybe I didn't hear it right, but I also heard 18-24 GPH. Is that right? LOL. I guess if you can afford the turbine the price per hour doesn't matter much anyway.
Not really, so long as you do not punch out 240HP at 17,000 feet, you need to actually FLY the aeroplane.
I have not used FL170 yet and I doubt I would but FL150-160 is not unheard of for us. We do get around 35LPH up there and a TAS around 160+ knots, depending on weight.
So if you keep your IAS under control, and hence TAS, it would be fine. The places where AVGAS is not easily found is growing, even here in Australia, however the problem we have is the distances you need to fly to find anything, could be a problem with Jet/Diesel as you will have less range so it remains to be seen.
If I said we paid about 60% of the AVGAS price for JetA1 and you burned 65% more for the same mission, price would be the same, range much less, but maybe maintenance would be better.
Depends on the initial cost too.
But if there is just NO 100LL well you are not in the price camp....Beggers and choosers they say.
7-8 years ago we looked at the -10 with the Innodyn but it never went anywhere, here is a small chance it could, and if it does, and its viable, maybe down the road it might get up.
I hope they are going to OSH so I can see it
