03-21-2012, 09:55 PM
Clipped wing RV-8
I love what Harmon did for the RV4 giving it a shorter and stiffer wing and coincidentally a higher G tolerance. Is there ANYONE who has done the same favor for the RV8???
03-21-2012, 10:14 PM
Even someone that has removed the fiberglass tips. Any improvement in top end speed?
03-21-2012, 10:23 PM
wing tips
Don't know if you're asking about cosmetics or performance, but 3 of us RV-4s that I know have gone to flat wind tips with fences to improve roll rate and retain stall speed for IAC competition without changing the rib spacing:
Same thing could apply to RV-8s.
Bill McLean
RV-4 Slider
Alabama
03-22-2012, 03:21 AM
I did it on the RV-6A (tip replacement)
Long story. Many tips; covered in other threads. It is faster. The roll rate seems faster but that is of no importance to me so no real tests performed.
Bob Axsom
03-22-2012, 04:56 PM
bonehead composites
Not sure what you'll get with these but looks interesting.
http://www.boneheadcomposites.com/m8...ng%20Tips.html
made of carbon fibre
Cheers
03-22-2012, 05:20 PM
I have a friend who did this on a Super 8, not yet flying. Cut the last outboard bay off and built shortened ailerons.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
03-22-2012, 05:53 PM
I have seriously considered this as well
In my case I have a fall back, with the tip tanks I can put back 1.5'. However at 180 HP with 21.5' span I get the feeling that going down two rib bays would be a mistake. If I get beat too bad at Texoma on march 31, 2012 I'll have to look at it again.
Bob Axsom
03-22-2012, 09:24 PM
great
great info guys. If my measurements are right, then leaving the wing tips off and making a flush end will take a full 2 feet off the span leaving it at 22'. The harmon II is only 2" less than that so it sounds like a quick fix for faster roll rate and less drag.
ANYone have templates for the flush tip and fences?
03-22-2012, 09:59 PM
JM Out of Indy?
Dennis Roberts
Wake Forest, NC
EAA 1114, Apex, NC
N713DR Super-7 IO/540  SOLD
http://www.drrv7.com
03-22-2012, 11:20 PM
great info guys. If my measurements are right, then leaving the wing tips off and making a flush end will take a full 2 feet off the span leaving it at 22'. The harmon II is only 2" less than that so it sounds like a quick fix for faster roll rate and less drag...
But... The HRII still has a full compliment of ribs (closer spacing), thus a stiffer wing.
RV-7 TU 904KM (reserved)
Construction Log
