Old 03-13-2012, 11:06 PM
Bill_H's Avatar
Bill_H Bill_H is offline
Default A safe gas can to carry along?
Is there a gas can to take 5 gallons along safely? One where the altitude change would not make a difference i.e. no venting issues? I can see going to a fly-in or other day trip to somewhere close that might not have car gas - and wanting to add 5 for the return trip.
My search here on the forum didn't turn anything up.
I don't mean a permanently plumbed solution - like Jetguy and Rdog's. (BTW guys - getting CLOSE! SKyview almost done, then it will be time to start engine testing!
Old 03-14-2012, 04:47 AM
BigJohn BigJohn is offline
Bill,
Why would you want to chance carrying 5 gallons of gas in the cockpit with you? Why not buy five gallons of 100LL from the FBO where you are going? Your engine is designed to run on either, and even if you prefer to normally run car gas your engine is not going to even notice if you run an occasional load of 100LL.
John
John Peck, CFII, A&P, EAA Tech Counselor, Flight Advisor.
?Master Pilot? Award, UFO Member.
RV-12 N37JP 120176 Flying since 2012.
One Week Wonder Build Team, OSH 2018.
VAF paid through 10/2019.
Old 03-14-2012, 05:48 AM
rocketbob's Avatar
Doesn't sound like BigJohn's been to an airport where the nearest FBO is a couple hundred miles away.
Any plastic gas can will do, but the bigger issue is keeping the cans strapped down so they can't move around.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 03-14-2012, 07:23 AM
Bill_H's Avatar
John Peck, good point - the query is kind of a "what if." A plastic can "should" work if it is very full so that the expansion effect on the air inside is nil as altitude increases. But I am wondering "what I don't know."
Old 03-14-2012, 08:56 AM
RV7ator RV7ator is offline
Default Filler 'er Up
Bill,
I've hauled thousands of gallons (in a 172) in "five" gallon plastic containers. Plastic doesn't scratch, but take care to keep the fill nozzle in contact with the container which you should set on the ground, and the container in contact with the airframe when emptying to ground electrical potential to prevent any static discharge.
The "five gallon" containers I use actually have a 5.8 capacity. I fill to 5.5 gallons for two reasons. 1. That leaves a .3 buffer so I don't slop when filling or emptying and a bit of expansion for different fuel temperatures. 2. (the important reason) A small air volume prevents farting gas fumes in climb. 2a. Don't fly with partial fill and remove the cap from the empty container.
John Siebold
Old 03-14-2012, 09:59 AM
badmrb badmrb is offline
Default Any heavy plastic should be fine.
I used to fly a zodiac CH601 that was subaru powered. I'd fly with a couple small "cans" strapped down behind me. I later found some smaller ones that would fit in the wing lockers and would fly from Colorado to Kansas with 2 small plastic cans in each wing. I'd land after a few hours. . stretch, and top back off before finishing the trip. There are lots of airports in western kansas, not many options when it comes to fuel, escpecially mogas.
There are some differences in plastic jugs though. Some are fairly thin and can really balloon up when they pressurize. I'd go with a couple smaller ones constructed with heavy plastic. I carry gas in back of a truck and on hot summer days they dont swell like the bigger ones.
I also like what some have done here with adding removable marine style tanks for extended flights.
As far as safety, you are flying around with a large tank already sitting behind you. I've had/ have several planes with header tanks sitting over your lap as well. My RV6 has several lines running under my feet that I sure wouldn't want leaking either. Make sure the can is strong, tight, and secure and should be good to go.
Old 03-14-2012, 10:28 AM
DHeal DHeal is offline
As I recall, these portable bladder tanks have been displayed at OSH: http://www.turtlepac.com/
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 940+ hours (as of September 2020)!
VAF donation through June 2021.
Old 03-14-2012, 02:25 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
We haul (6) ea. 5 gallon plastic containers of gas to our fly-in island property with my friends C210 on a regular basis. We have a Chevy Suburban, a four wheeler and generators that need gas on a regular basis. It really is not an issue. Don't fill to the top, say fill to 4.5 gallons, strap them down and go fly. BTW... there are no gas stations on the island.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 03-14-2012, 03:42 PM
Mark Albery's Avatar
Mark Albery Mark Albery is offline
I believe these are popular with back country and arctic pilots in Canada/Alaska.
I've no experience of them, but they can be rolled up and stored easily when not in use.
The Turtlepac alternative is very good quality, but is very expensive.
Old 03-14-2012, 04:22 PM
FORANE's Avatar
FORANE FORANE is offline
I have plumbed in a fuel line connected to a fuel selector valve on the proximal end and one of these http://www.amazon.com/Sierra-Interna...1763552&sr=1-3 on the distal end.
Occasionally I carry a tank like this:
http://www.amazon.com/attwood-8867-2...1763384&sr=1-3
If I want to use it airborne, it is just a matter of plugging into it.
