Old 03-08-2012, 09:42 AM
denbobp denbobp is offline
Default Bushings in control sticks
It appears that AN 4 bolt can not slide through the control stick brass bushings without reaming the bushing. Has anybody run across this scenario. Thanks
Old 03-08-2012, 10:03 AM
SHIPCHIEF SHIPCHIEF is offline
IIRC;
All the brass tube bushings required running a drill or a reamer thru to allow the bolt to fit.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
Old 03-08-2012, 10:56 AM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Originally Posted by SHIPCHIEF View Post
IIRC;
This is correct. When working on -7 aileron bell crank brass bushings it states that this is also typical for the bushings at the controls.
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
