Old 03-03-2012, 08:50 AM
G3i Ignition's Avatar
G3i Ignition G3i Ignition is offline
Default Tip: G3i, & Those darn adel clamps ##!% SOLVED
Those darn adell clamps ##!% SOLVED
Came up with today with the frustration of holding two adell clamps with needle noses and hemostats. Tuff problem made easy with a small piece of metal.
Yeah!
Thomas Shpakow
http://www.G3ignition.com
Follow G3i on Facebook.
www.facebook.com/pages/G3i-Ignition/243104229291
Old 03-03-2012, 08:54 AM
SmilingJack's Avatar
Thanks! I was wrestling them a couple days ago!
That simple idea you came up with would have come in handy!
Me thinks I will make one for the next time
John Mastro
RV-8
Old 03-03-2012, 09:05 AM
paul mosher
Posts: n/a
Default clamps
I just safety them closed with thin safety wire and cut it off after installing hardware.
Old 03-03-2012, 11:26 AM
Jerry Cochran's Avatar
Jerry Cochran Jerry Cochran is offline
Default This begs the question...
WHY are they springy? Does that serve some useful purpose? If so the reason escapes me.. Just seems they would be a lot easier to work with if they weren't THAT springy...
YMMV
Jerry Cochran
Sherwood, Oregon
RV-7a 707DD Bot from David Domeier 12/01/11
Lycoming IO-360 Catto 3 blade Panel upgrade in progress
RV6a 18XP 1st flite 03/21/07 sold to Dale Walter 10/22/2011
Superior IO-360, Hartzell Blended, GRT/Dynon
Happily "autopaying" DR
"Suppose you were an idiot, and suppose you were a member of Congress; but I repeat myself."
Mark Twain
Old 03-03-2012, 12:58 PM
Captain_John's Avatar
Thomas, That is a clever little trick!
I am soooooo gonna do that!
Thanks for sharing it!
CJ
The experiment works!
Old 03-03-2012, 01:51 PM
DakotaHawk's Avatar
Adel clamps are kind of like your second grade teacher. All she wanted to do was teach us new vocabulary words!
Scott "Grumpy" Stewart
#866 on the Van's RV-7 hobbs
#6563 on Van's generic hobbs
Arlington, WA
Old 03-03-2012, 02:23 PM
Dennis_I's Avatar
Dennis_I Dennis_I is offline
As said earlier in a post, a loop of lock wire will also do the trick
Dennis Isaksson
G?llivare, Sweden
Grew up with an RV-4, SE-XIO
Now: RV-8, Showplanes Fastback. #83218 Under construction, SE-XXO
Engine and avionic installation in progress
Old 03-03-2012, 06:43 PM
rvdave rvdave is offline
Great idea, why didn't I think of that, I've just struggled with needlenose & grunting but not any more, thanks for the tip.
