Shield
5 wire as stated above. I did have EMI problems with the indicator and had to shield lines. Some folks do and some don't and probably driven by routing and the Ray Allen indicator. There does not appear to be a 5 wire shielded cable so ended up with a three and a two. Ray Allen said they did not know of problems,but did later admit that they were working on a different power supply, so they knew. Spent 3 days chasing problem with one of my satellite electrical guys and we definitely tied it to interference. Hope you don't have a similar problem, but just wanted to minimize your troubleshooting if you do. Don
