Old 02-23-2012, 01:33 PM
erich weaver's Avatar
Default cheap borescope alternatives
hey guys
I was poking around on the internet looking for borescopes to permit images and videos of cylinder walls, valves, and piston heads. There were a couple of long discussions with lots of impressive photos on the "BeechTalk" forum. They are getting good results using cheapo cameras like these:
http://www.ebay.com/itm/NEW-6-LED-De...item19cdcd88d3
and
http://www.chinavasion.com/product_i...a-with-lights/
These cameras are plugged into a lap top with a USB connection. The BeechTalk group is building a nice archive of photos with discussion that is really useful. Mike Busch among others recommends frequent borescope use to detect damage before it causes a major problem, and as a better diagnostic tool than the standard compression test. For these prices, its worth a try
erich
Old 02-24-2012, 08:13 AM
rv9av8tr's Avatar
rv9av8tr rv9av8tr is offline
Don't bother with the boroscopes sold at Harbor Freight... you get what you pay for. Don't ask how I know...
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
Old 02-24-2012, 09:21 AM
clevtool's Avatar
clevtool clevtool is offline
We sell one that I tested just this week in a continental. The 9mm camera lets you get into the cylinder and the mirror lets you see the valve. It has a close focus of .4" so it works quite well. The mirror also screws on this model vs. the clip on so it won't come off inside the cylinder. 640x480 quality on a big laptop screen makes for a nicer display than the $500 model. Also works well for behind the panel and in the forward fuse interior area to see those things that are difficult without crawling in upside down. Makes push rod tube bolt inspection easy as well.
http://www.cleavelandtoolstore.com/p...mber=ISG050-09
Mike Lauritsen
Cleaveland Aircraft Tool
800-368-1822
www.CleavelandTool.com
mike.toolman (at) gmail.com
Like on Facebook - Follow on Twitter - See on YouTube
Old 02-24-2012, 09:30 AM
aerhed aerhed is offline
I have a small mirror on a handle that fits in a spark plug hole. I can see both valves and the entire cylinder wall with it. It has located several bad valves and a couple dozen scored jugs. No batteries, and...its in color.
Actual repeat offender.
Old 02-24-2012, 09:39 AM
DanBaier's Avatar
DanBaier DanBaier is offline
Default Question
Originally Posted by clevtool View Post
MIke...a dumb question I'm sure - but is this a camera that can capture images that can be saved on the PC or do you have do screen saves, etc.?
Dan
RV7A (N7101) - Flying 10/2008
CFI- SE/ME/Inst
A&P
KC2ZEL
Old 02-24-2012, 10:37 AM
Space Cadet's Avatar
Space Cadet Space Cadet is offline
Default clevtool Clarification?
We sell one that I tested just this week in a continental. The 9mm camera lets you get into the cylinder and the mirror lets you see the valve. It has a close focus of .4" so it works quite well. -
The web site link says the focus is 4", not 0.4". Which is it?
Dwight
RV-10 #40762 - 100 hrs+
Denver, CO
Old 02-24-2012, 06:56 PM
Low Pass's Avatar
Low Pass Low Pass is offline
I have a different take on one of the Harbor Freight items. Specifically the $199 camera/scope.
http://www.harborfreight.com/high-re...der-67980.html
The camera head isn't articulated like the $10-20,000 fiber scopes I've used in the past. But considering the price, the recording capability (video, still and audio), writes to an SD card, resolution and cordless power capability, it's a nice tool. Quality is also very good for $199.
Old 02-25-2012, 08:00 AM
speyers's Avatar
speyers speyers is offline
Default Snap-On BK-6000
Mike Busch recommends the BK-6000 from Snap-On. They are going for about $500-$600 on Ebay. ($800 new) Would be good for an EAA chapter to have or perhaps to share amongst a group of owners. The BK-6000 is able to take video and pictures, store them on a SIM card for sending via e-mail or showing back at the office is needed.
Recommend listening to this webinar so that you know what your looking at through the borescope. Its called "All about cylinders" and is presented by Mike Busch. He says that if you watch the weinar you will know more than most A&Ps! Since I am one I figured I should watch it as well. Very informative.
http://www.eaavideo.org/video.aspx?v=991490765001
-David
Old 02-25-2012, 09:08 AM
rocketbob's Avatar
I've caught cracked cylinders that had great compression a few times using a Lenox borescope. The cracks were hard to see even with its good optical clarity so I'm a little dubious of the effectiveness of a low-resolution camera, regardless of price.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 02-25-2012, 09:11 AM
-David
I'm not knocking what David is saying, all good stuff indeed. Just sayin' (again) check what's being done with the cheap stuff, as posted on the BeechTalk forum. Excellent photos of exhaust valves.
Erich
