  #11
Old 02-22-2012, 09:19 AM
Wayne Gillispie Wayne Gillispie is offline
Originally Posted by Wayne Gillispie View Post
The extra heavy items added aft of cg are: pc680 aux beside 925, 10 ga wire to front, 6 space hot bat fuse block, extra contactor/#2 wire to interconnect to main bat, baggage led's/switch, two cig lighter accy ports, 6 spare 18 ga wires from panel to rear for future use(ads-b, etc).
The reason no ballast is needed on mine solo or two up front is the above items which probably weigh 25-28 lbs, plus I always have oil, tools, covers, tiedown kit, first aide kit and survival kit in baggage area(another 25 lbs). If I did not have these very useful items then one would definitely have to put 50 lbs of something in the baggage area.
I really like the way it flies fully loaded better than solo...stable, responsive, and very little trim adjustments between takeoff, cruise, landing or go arounds.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Old 02-22-2012, 01:28 PM
Wesael's Avatar
Wesael Wesael is offline
Originally Posted by tfarrell839 View Post
I have a battery box for an Odyessey PC680 that is designed to mount to the firewall. I personally would drill this out significantly with lightening holes. This is what I would use to mount it. I'll try to find some pics of an install on an RV-10, or at least of the space where you could install it and post those later.
Is this the battery mount kit that Van sells for the PC680 ?
Weasel
RV-4 715hr Sold
RV-10 "School Bus"
I have changed my User Name to the correct spelling as it became availible. Please direct all correspondence to Weasel
Old 02-23-2012, 12:34 PM
tfarrell839 tfarrell839 is offline
Default Batt Box
Wesael,
Honestly I can't remember. I think it came from Odyssey directly , but I don't think they offer it any more. It is made from 3/32. I don't know what Van's offers exactly, maybe someone has a pic of a vans tray.
Good luck.
Old 02-23-2012, 12:44 PM
Wesael's Avatar
Wesael,
Good luck.
Thanks for your help. I could not find specific information on it so I just ordered the one that van offers for the 680.
I hope it is the same....I like that set-up
Weasel
RV-4 715hr Sold
RV-10 "School Bus"
Old 02-25-2012, 02:31 PM
Ron B. Ron B. is online now
I took three photos of our firewall battery installation today. I've tried inserting photos before and it a pain for me. If someone would like to give me their e-mail , I can send them and you can post them for me.
Ron
Old 02-25-2012, 02:47 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Ron
http://www.vansairforce.com/communit...d.php?p=286734
Start at post 30.
You do not insert a photo, you have the photo hosted on a website that specializes in such things, and then you insert a link to the photo.
Good luck.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 02-25-2012, 03:22 PM
Ron,
I'll host your photos and post them. tim at aircraftersllc dot com
-Tim
Old 02-26-2012, 06:54 PM
Default Battery box Firewall Photos
Here are the photos from Ron.
-T
Old 02-27-2012, 09:37 AM
Thanks Tim
Ron
Old 03-01-2012, 12:01 PM
rvdave rvdave is offline
So is the vans 680 battery mount the same as the prior photo?
