Old 02-16-2012, 10:44 PM
RobinHou RobinHou is offline
Default The Threaded Rod End (AN490HT11P)
I am putting together my F-789 pushrod, but run into couple issues:
1. The Threaded Rod End (AN490HT11P) does not fit the pushrod. I assume I can sand down the threaded rod end until it fits into the pushrod, correct?
2. When I tried to thread the threaded rod end into the Rod End Bearing F3514M, it only went in about 1/4". I then tried an AN316-5 Nut and it only went on the rod end about 1/8". It appears the threaded portion of the rod end is too big. I have no idea how to resolve this issue. Suggestion?
Thanks in advance,
Robin
Old 02-17-2012, 08:02 PM
engineerorange engineerorange is offline
For issue #1, make sure you don't have a burr on the inside of the tube where it was cut that is keeping the threaded rod end from sliding in.
For issue #2, something is wrong. Rod end could be defective or the threads are damaged from handling somehow. Hard to tell without seeing it.
mangling aluminum since May 2009
RV7-A, flying
RV8 under construction
Old 02-20-2012, 09:23 AM
truflite truflite is offline
Default Threaded rod end
I just did this yesterday. I have a lathe in my basement. So I chucked the threaded rod end to the lathe, lightly. I took a fine file to the OD. I then polished it with 40 micron mylar backed "sandpaper". I did this twice and got a snug fit. Also, make sure you deburr the end of the tube and swab it out with a small piece of rag and a length of dowel rod.
I had a problem with the nuts as well. There is a small indent on the nut. I assume it is to cause an interference fit. I simply started the nut by turning it over and threading it on from the other end.
Before riveting, I applied a thin coat of an anti-oxidizing compound to the tube and the rod end to replace the cadmium coating of the rod end.
Dave
Old 02-20-2012, 10:56 AM
DaAV8R DaAV8R is offline
I had to turn mine down also. I didn't have the correct equipment so I had to chuck them up in the drill. Kind of a mickey mouse operation but it worked.
Robert Williams
Lee's Summit, MO
RV-8 - Empennage & Wings Done
Working on Fuse
O-360-A1A
1946 Cessna 120
Old 02-20-2012, 06:16 PM
SeanB's Avatar
SeanB SeanB is offline
Dave,
Can you tell me what compound you used for the threads? I had some rod ends welded for the aileron push rods, and the cadmium burned off.
SEAN BLAIR V7
Colorado Springs, CO
http://www.mykitlog.com/sblair
2020 VAF SUPPORTER
Old 02-22-2012, 05:49 PM
I used some No-Alox. It is an anti-oxidizing compound used in the electrical industry. Use sparingly but coat everything. Wipe off excess.
Dave
Old 02-22-2012, 06:28 PM
SeanB's Avatar
Thanks, Dave. I look into it.
SEAN BLAIR V7
2020 VAF SUPPORTER
