Old 02-18-2012, 03:16 PM
RV7AJeremy's Avatar
RV7AJeremy RV7AJeremy is offline
Default Things to do while deployed
I am getting ready to go on a 6 month deployment to the desert. I will have a little bit of free time over there and I am planning to design the electrical system and the panel in auto cad . Can anyone else think of other progress I can make on the project while I am away from the project?
Jeremy
ATP, CFI, CFII
RV-7 N424JD KCHD
EAA Tech Counselor
2017 Bronze Lindy
Old 02-18-2012, 03:31 PM
frazitl's Avatar
frazitl frazitl is offline
Default just what i was thinking.
I spent a lot of time on both. No harm doing early. Its a lot easier to change the plan than the already run wires or cut panel holes. If you are doing your own panel wiring, lots of time needed to research hookups. As you continue your build, you will be refining your plan the whole time. Read and understand the aeroelectric connection materials.
Stay safe...
Terry F.
RV 7A N457RV
250 hours and lovin it!
Southern Nevada EAA Chapter 1300 - www.eaa1300.org
Paid VAF 03/17
Old 02-18-2012, 03:42 PM
chaskuss chaskuss is offline
Talking I advise shameless begging
Jeremy,
On the issue of designing your electrical system using AutoCAD, why not ask others for a copy of their AutoCAD designs. It would help if you list what components you plan to use. Never hurts to collect diagrams for other components, as you never know when you will change your mind. I can supply DWF drawings of my systems.
Charlie
Old 02-18-2012, 03:47 PM
SmilingJack's Avatar
Default POH
You can start building a Pilot Operating Handbook.
Regards,
John Mastro
RV-8
Old 02-18-2012, 04:37 PM
RV7AJeremy's Avatar
Default PM sent
Originally Posted by chaskuss View Post
Jeremy,
Charlie
Charlie, PM sent, thanks!
Jeremy
ATP, CFI, CFII
RV-7 N424JD KCHD
EAA Tech Counselor
2017 Bronze Lindy
Old 02-18-2012, 05:34 PM
az_gila's Avatar
az_gila az_gila is offline
Thumbs up
Download the symbls and schematics from AeroElectric Bob as a starting point.
http://www.aeroelectric.com/PPS/
If you are using TurboCAD cos it's less $$$, I have a set of symbols.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 02-18-2012, 05:49 PM
John Collier John Collier is offline
Default Panel and stock vs. aftermarket?
I designed my panel....got other pilot's inputs. Put it together on epanel builder...used the CNC service when I got back. I also used the aeroelectric connection extensively...but I "overbuild" the system using the endurance bus concept. I didn't realize at the time....most of my glass would have its own back-up battery. In hind sight...I would have just used one fuse block behind the panel.
The other task you could consider is what you are going to take out of the kit (if anything)...and replace with aftermarket....Groove gear, tail wheel, etc. The forums are great for this...and you can get into the plans to figure out what to delete from your order when you return home.
Best of Luck
John Collier
RV8
N774BC
Niceville, FL
Old 02-18-2012, 06:04 PM
Paul K Paul K is offline
Default Paint design
Can't tell you how much time I spent on the paint design. Thousands of colors, trying to make it look fast, nose or tail art, etc.
I spent hours on Airlinersdotnet looking at what looked good and what doesn't.
Thanks for serving and take care.
Paul K
West Michigan
2020 donation made, exempt but worth every dime!
Old 02-18-2012, 06:12 PM
Default copy of acadlt
Jeremy,
My son in law just got back. He was there for a full year. He is an AF JAG, back at Maxwell now. I wanted to make sure you had a copy of acad if you need one. I have an un-used licensed copy that I would be willing to let you use while you are deployed. Let me know if you need it. Thanks for your service.
rockwood
Old 02-18-2012, 06:37 PM
Bugsy's Avatar
Bugsy Bugsy is offline
Default Me to
Im going for a 365, leave in june. Email me and if nearby we can compare panels
Paul.gardetto@langley.af.mil
Paul 'Bugsy' Gardetto, Col, USAF (ret)
Milwaukee, Wisconsin (Timmerman Field)
N377KG - Flying (250 hrs)
RV-7A, Aerosport O-360, WW200RV
Advanced Flight 5400
Avidyne IFD440
Paint by planeschemer.com
